'61 Lark tire size
  • '61 Lark tire size
    Trying to get my Lark, that I recently got, drivable, The tires rub on the inside of the front fenders when I make sharp turns, left or right. I'm pretty sure it has the wrong size tires on it, they are P215 /75/R15. Would like to know the size of a reasonably priced tire that is readily available and fits,if there is such a thing.
    P205/75/R15 have worked on my Avanti. I believe Cooper and some others still have that size.
    78 Avanti RQB 2792
    64 Avanti R1 R5408
    63 Avanti R1 R4551
    63 Avanti R1 R2281
    62 GT Hawk V15949
    56 GH 6032504
    56 GH 6032588
    55 Speedster 7160047
    55 Speedster 7165279
      Ditto that-I have 205-75s on my ‘60 Lark and they fit great!
        Do you have stock or aftermarket wheels? If aftermarket, you need to have the correct offset and backspace
        78 Avanti RQB 2792
        64 Avanti R1 R5408
        63 Avanti R1 R4551
        63 Avanti R1 R2281
        62 GT Hawk V15949
        56 GH 6032504
        56 GH 6032588
          You only have one size Larger than most are using on Larks, so checking the Wheel Backspace may very well be needed as suggested.
          Also collapsed Front springs will contribute to that condition.
          Is this a Lark Six or Eight?
            It is an 8 cylinder, The wheels appear to be stock. If I figure out how to post a photo I would send a picture. The 2.15's fill the wheel wells quite a bit. Does anyone know the diameters of the 2.05 vs. the 2.15 tire? Just remembered to mention that the front fenders have been replaced with fiberglass. Is that known to be a problem?
              https://tiresize.com/calculator/
              Bellingham, WA
                I am running 215/70r15 on aftermarket 6" rims(same height as 205/75), just a little wider and they fit great, improved handling and drive nicely on my '59 Lark HT.
                Bill
                  Checking around now for prices on 205/70r15. Thanks for all the input>
                    Graylark
                    Here are the load capacities at 32 PSI :
                    205/70r15 1415
                    205/75r15 1455
                    215/70r15 1495
                    215/75r15 1596
                    By using your proposed size of 205/70r15 you are losing 320 lbs total capacity (80 x4)over the size I recommended (215/70r15) which will result in lesser performance(poorer road holding, steering control and poorer tire wear) at any given pressures.
                    There is also a substantial height difference.
                    If you don't want to install wider wheels for the 215/70r15 size then 205/75r15 would be a better application. However with your original wheels not just being very narrow, they are also pushing 60 years of age, so definitely not recommended for safety reasons.
                    Bill
