Help Deciphering Serial and Tag
  • Help Deciphering Serial and Tag
    Hello again everyone. Well, finally went out and got the numbers off that 1955 Studebaker.
    Serial Number: 8842072
    Tag Under Hood: 16G8 K5
    285
    Any help in deciphering these numbers is greatly appreciated. Thank you.
    16G8 - 1955 Commander (Commander = V8 = good)
    K - hardtop (good! The two most desirable body styles are the C-coupe and K-hardtop.)
    5 - Regal trim
    285 - sequential body number
    I'll be no help with the serial number; depending on where in the model year it falls it should have come with either a 224 or 259ci engine (same block 224/259/later 289, just different strokes.) I'm guessing the smaller one based on the body number. Nice car, anyway. Info can be found in the '55 shop manual, which has been reprinted (I just don't have it in front of me) also if you have the shop manual you can tell if the engine serial no. falls in the expected range for the car. Should have either a DG-250 automatic or a 3-speed stick, with or without overdrive. You might be able to find a paint code sticker stuck to the bottom of the glovebox, but it may have fallen off or be unreadable by now. If this is a potential resto project you already have enough info to order the build sheet.
      5 - Regal trim
        Thank you for the information. We're not exactly sure as to what we are going to do with this car. Most likely part it out since it doesn't have a title, eh, we'll see.
            The serial number range also tells us the car was built in Los Angeles, and is a so-called 'early model' with the 224 engine.
            Dwain G.
              Dwain G.
                If it's a decent, solid car - no title is not much of an issue![:I]
