buying 54 coupe
  • #46
    Oops I managed to get carried away with the pics...oh well, its a little like saying I have too many pictures of Marilyn Monroe!
    • #47
      You would have to Install quite a Lot of expensive hard to find Trim to convert it to a C5 Regal like that from a C3 Deluxe.
      And it still would look like a Taxi with those Black Tires.
      • #48
        Everyone got so carried away with the discussion about the wheel covers, no one remembered to answer Mr. Walgamuth's questions in posts #6 and #7. Can anyone give him advice to fix the problem with his hood?
        Mark L
        • #49
          What do you really think? The wide whites just don't do it for me. They look good, but not on my car.
          Thanks for thinking of my hood.
          • #50
            IIRC, his hood has a bent corner in the back (or both corners?) and a hinge problem. My '54 had bent hood corners when I bought it and the body man I took it to was able to straighten them before the repaint and the hood still looks and works great all these years later. I would definitely seek out a good auto body man to do this job before replacing the hood.
            • #51
              Yeah, probably makes sense. I am guessing the hinges are too tight. It appears to have some nut and bolts which could be tightened too much.
              Comments?
              • #52
                I put the Classic Enterprises hood stiffeners on the Possum Smasher. I used pop rivets and it took less than a hour to do it. I am sure welding them is preferred but I did not heat up the paint and have confidence they will be fine. If I repaint the car, I will weld them during prep. Until then, I will keep an eye on them.
                • #53
                  How did you attach them please? Do the rivits show?
                  • #54
                    Comments?
                    Sorry, I didn't notice the comment s on the hood earlier. I just got caught drooling over the beautiful example of a 53. From my experience with the hood hinges , you need to have the hinges on the car and free. Then put the little torsion looking bar (connector between hinges on . If it is bent and the two sides are not in sync, you got a hood problem. Get this done and then put the hood back on ( might have to take one end loose on bar) and adjust by hinge to cowl bolts being (almost tight), so you can bump a little before final tightening. Do remember that the nuts on the hood to hinge, DO NOT GET SNUG ! They are castle nuts with a cotter pin for a reason ! This has worked on several 53's for me .
                    • #55
                      I used the long hood stiffeners now I can grab that hood any old way and pull it up. Well worth the money and time.
                      • #56
                        Well that really changed the look!
                        • #57
                          I put the rivets right along the edge. Click image for larger version
                          They are not very noticable. I can always dab some blue paint on them.
                          • #58
                            Can you say how long they are please?
                            • #59
                              I guess that looks ok. If I find a good hood later I can install it then.
                              • #60
                                I believe there some 19 inches look up Classic Enterprise repair and replacement parts for Studebaker.
