Studebaker Semi/Tractor
  • Studebaker Semi/Tractor
    I am looking for a Studebaker Tractor, and I see a lot of Cab and Chassis but I cannot find the wheelbase for a Tractor anywhere in notes that I have, books that I have, ect
    Does anyone know what the wheelbase of a Tractor was from the factory. Was there a standard wheelbase for a Tractor? On the charts I see wheelbases from 132 to 212.
    I found a trailer toter online, but it looks like it has been shortened. I want a true Tractor/Semi.
    Thanks
    FWIW, the trailer toter has a telescoping frame and two driveshafts, so it can run long or short wheelbase. When length regulations required a very short wheelbase, remove the long driveshaft, pull the pins, winch up the frame, install the short driveshaft, reinstall the pins and good to go. To go back to long wheelbase, reverse the process
    jack vines
      Since Stude did not offer factory tandem axles on their trucks, nearly all had a single rear axle. The wheelbase most commonly used for road tractors was 131", which was available on all 1, 1.5, and 2-ton trucks.
      Skip Lackie
        Factory photo of an 8E40 - 131 WBClick image for larger version
Name:	?u=http%3A%2F%2Fimage.trucktrend.com%2Ff%2F58828527%2Bre0%2Bar0%2Bst0%2F1962-studebaker-diesel.jpg&f=1&nofb=1.jpg
          What Diesel engine did these trucks use?
            They used a Detroit Diesel, either 3-53 or 4-53. Used from 1962-64.
              Carroll Studebaker used this one to bring his electric cars and buggies to the 1980 Gettysburg National.
ID:	1861536 The sun flare was caused by an unknown pin hole in the bellows of my Agfa Isolette. Sorry about that.
              '33 Rockne 10,
              '51 Commander Starlight,
              '56 Sky Hawk
Name:	Asa Hall's trucks.jpg
ID:	1861538 And Asa Hall's rig, also at Gettysburg 1980.
                '33 Rockne 10,
                '56 Sky Hawk
                  Thanks for the information. No wonder I could not find anything on specifications for a Semi.
                  So in other words, Trucks used for hauling a trailer would come out of the factory as a Cab and Chassis and the owner would put a Fifth Wheel on the chassis?
                    Does anyone know of a Tractor for sale? I seen a 47 in South Bend a while ago, but was not able to get it at the time.
                      Basically, yes. Studebaker offered several "factory" bodies, including pickup, flatbed, and stake. The pickup bodies were made in house, while the flatbeds and stakes were actually built by Edwards Iron Works in South Bend. Edwards also offered road tractor 5th wheel conversions and other truck bodies, but I don't think Studebaker ever offered those as a single-price, factory option. However, they may have done so once they started offering Detroit Diesel engines in all but the lightest truck models in late 61. Would be glad to be corrected on that.
                      Skip Lackie
                        It would REALLY be Cool if someone could locate and Purchase Lionel Stone's Former Paxton Products Div. of Studebaker's "Bonneville" '63 Transtar Semi Tractor! . .
                          Are you sure it's not in your garage already, Rich!!?!
                            Not sure Craig, I can't see it for the 50 Others in the way!
                              Not a tractor any more. 20years back I restored a 62 8E45. It was a 131 WB with a dump bed. I made it 195 WB and put on a flat bed. Powered by the 4-53 Detroit Diesel, 5 speed direct , A auxiliary Brown and Lipe over and under transmission and the optional hi speed differential. It also had full air brakes. I sold it to George Orphanidys . The last I herd it could be purchased. I don't have a picture in this computer. It was in several Turning Wheels as a platform for the Studebaker Truck Farmers picture.
