Avanti models, homemade.
  • Avanti models, homemade.
    Here is a cluster of photos of two cardboard Avanti models that I designed and built. They are each about 9 inches long. I apologize for the small size of the images. These are from scans that were made of photographs of my models. I did not have editable images of these models in an uploaded photo software program.
    Click image for larger version  Name:	 Views:	0 Size:	18.2 KB ID:	1852492
ID:	1852515 More photos. Scans aren't as good as I had hoped for.
    Click image for larger version  Name:	Scan_20200824 (5).png Views:	0 Size:	22.8 KB ID:	1852516Click image for larger version  Name:	Scan_20200824 (6).png Views:	0 Size:	22.0 KB ID:	1852517Click image for larger version  Name:	Scan_20200824 (3).png Views:	0 Size:	21.7 KB ID:	1852518
    Last edited by Crowel, Mark; 08-24-2020, 12:14 PM. Reason: Trying to improve image sizes.
      Anyway, here some of the build photos, as one of these was being constructed. Interiors take as much time to build as the bodies.
ID:	1852524Click image for larger version
ID:	1852525Click image for larger version
        Building the exterior. I call it "strip-and-panel" construction. A strip of cardboard is glued between two profile shaped panels, to form the body component. The body components are then glued together to compose the whole body: usually a center section flanked by two side sections. I use the type of lightweight 1/32" cardboard usually found on the backs of writing tablets.
ID:	1852539Click image for larger version
ID:	1852542Click image for larger version
          Wheel construction, mounting in center section, and adding of side pontoon.
ID:	1852548Click image for larger version
ID:	1852549Click image for larger version
