Did ya know that the Valves CAN be adjusted on side Valve Sixes by just removing a Valve Door?
Notice I did not say it was easy!
If it has been leaking a lot from those Valve Covers, there are 12 small holes under the Lower part of the Cover Gaskets that had a factory fix to install small Lead Carb. Plugs in the holes, because there IS Oil Pressure to the Lifters in them! They MAY already be plugged.
