Mystery engine!
  • Mystery engine!
    I have been trying to identify an engine that came with my 1950 willys M38. I have narrowed it down to what I think is a Studebaker 170 but not sure on what year and thats all I can find. Any help would be appreciated as I am trying to get parts.
    It is a Champion six. If I read the chart right, it's a '57 Champion 185, based on the serial number in the first pic. Champions were a popular swap into jeeps of that era, since the Jeep transmission would bolt up directly to the Champion bellhousing. Somebody here may be able to confirm if it is a 185 based on the block casting number. They raised the deck height a little on the 185 block, and it has much larger journals than the preceding 170 block.
      Thank you, that helps so much.
        Bet that works good.
          Those "1"s stamped as "I"s are a giveaway!
          Brad Johnson,
          '56 Sky Hawk in process
            Definitely a 185 block. Casting 533870 was used from 1955 to 1958. The block was cast in 1957. The serial number says it's a '58 engine.
            D 'N Q RACE ENGINES
