Hi,
I just picked up a 1961 champ 3/4 ton and it needs a lot of help. Its had the original 259 replaced with a 259 out of a 1963 car, however there is a block off plate bolted on the block where the filter would be and someone has installed an upside down spin on oil filter which is bolted to the oil fill pipe ontop of the engine.
The main problem so far is the engine mounts. The drivers side mount is missing and the engine is hard mounted to the frame on that side with pieces of angle iron which are welded to the mount bracket attached to the frame. The passenger side has the engine mount bracket on the block but it has several pieces of metal and small rubber disks acting as a mount, all of it held together with a bolt which is way too long.
So far I have bought a rebuilt kit for the carburetor, new fuel pump, fan belt, air cleaner,and oil filter. I really want to hear it run before I dump a lot of money into it. If anyone knows where I can get the passenger side engine mount bracket I could really use one. Any help is greatly appreciated
