Front end suspension tool needed
  • Front end suspension tool needed
    I am working on a 63 R2 Lark. I am replacing the bushings on the front end upper and lower A arms. I see in the shop manual a special tool is needed so that the A Arms do not get bent when pressing the bushings in. Where can I buy one of these tools?
    J5474 ? or J5472 ?
    Any input is greatly appreciated. Thank you
    58 Packard Wgn (Parade Red)
    58 Packard Wgn (Park Green)
    58 Packard Sdn (Shadowtone Red)
    62 Daytona (White)
    63 R2 Lark (Super Red)
    57 Packard Wagon parts car
    57 Packard sedan parts car
    58 Packard 2 dr hdtp parts car
    look here ( J-2044):
    https://www.studebakerparts.com/stud...age=tools.html
    J5474 ? or J5472 ?
    62 Daytona (White)
    1951 Rod
    1962 Champ
    1963 Avanti R1
    1963 GT Hawk R2 4 speed
    1964 Daytona Convertible
    2006 Avanti Convertible
    1951 Custom
    1958 Packard Hawk < resto project
    1962 Champ
    1963 Standard R1 4 speed
    1963 Avanti R1
      That is not the right tool for pressing the bushing in. Thanks for your input
      62 Daytona (White)
        if you are talking about the rubber bushings, just cut a piece of angle iron to the distance between the "ears" of the A-arm to support it and drive the bushings in with a large socket and an extension.
          I made on from a section of fence pipe, and a sawzall to notch for shaft.
          [img=left]http://i52.photobucket.com/albums/g27/Rosstude/OldWorld2005002.jpg[/img=left]
          Ross.
          Riverside, Ca.
          1957 Provincial X2
          1958 Transtar
          Ross.
          Riverside, Ca.
          1957 Provincial X2
          1958 Transtar
            I did roughly the same thing as Ross.
            1963 Cruiser
            1957 President two door
              I rented "tool #25" from my local Checker Auto Parts for the A arm bushings on my 53 Commander. It worked slick. The rental cost like $6 for 2 days. It looks like a big C clamp and has various collars to clamp the bushings. There is no risk to bending the A arms with this tool since you are only working with one side of the arm at a time.
              Rob
              Grand Forks, ND
              Rob in ND
              \'53 Commander resto-mod (work in process)
                Look for my post on this topic in the Technical Talk Forum,
                http://forum.studebakerdriversclub.c...TOPIC_ID=19820
                Here is what I use:
                For the upper Control arm, a simple piece of 1 1/4" angle iron cut 6 7/8" long will do. I insert it between the control arms, install the shaft(be sure it is installed with the offset towards the engine), place the bushings over the ends, and use (2) large sockets over each bushing. They must fit OVER the rubber if you use OEM-style bushings. The Delrin bushings can be pressed in with a hardwood, or steel spacer.
                Luckily- I have a vice that opens enough to press the upper CA bushings in. If you don't, you can drive the bushings in with a large hammer (helps to have 2-people), or use a press.
                ***NOTE: the photos of the upper control arm below show the offset the WRONG way. When I flipped it over(for the photo), I had it reversed. You can just rotate the shaft 180 degrees before installation.
                For the lowers, The width is 10 7/16". I welded up this tool- to clear the larger mounting lugs, and some shafts have a tie-down eye on them. The bushing installation is the same as for the uppers.
                Ray
                www.raylinrestoration.com
                  Thanks
                  I was waiting for someone to respond to this post. Excellent and easy to make tool to eliminate distorting the A-arm.
                  Allen
                  1964 R2 GT Hawk
                  1963 Daytona Convertible
                  Oakville, Ontario.
                  Hamilton Chapter
                  1964 GT Hawk
                  PSMCDR 2014
                  PSMCDR 2013
                  Victoria, Canada
                    Thanks to everyone! And thanks for the pics. They help greatly!
                    62 Daytona (White)
                      A very timely and useful topic. I was just getting ready to overhaul the front suspension on mine over the holidays. Thanks.
                        My photo tutorial for doing bushing installation using a c-frame press is posted here. No fabricating needed.
                        Clark in San Diego
                        '63 F2/Lark Standard
                        www.studebakersandiego.com
