Mini TROG racer
  • Mini TROG racer
    It looks like this project may make it to completion. It has been a mind bender because of the lack of detail pictures. Right now most pieces are just hung together. Click image for larger version
ID:	1825928Click image for larger version
ID:	1825929Click image for larger version
    Whoa, Very cool !! Great work, 52-fan!
    -Matt
    1963 GT Hawk
    1960 Metropolitan Convertible
    1972 AMC Javelin/ AMX
    1956 Cushman Eagle
      Thank you. I lost contact with the builder of the real car. He was going to send me more pictures, but I finally just went with what I had.
        Did you hand make all of the parts? That "Champion" engine looks great. I am envious of your modeling skills. Great job.
          I started with the engine block and transmission from the AMT 40 Plymouth kit since it is about the same size. I built my own timing cover for the front and made a head with the Champion bolt pattern and plug locations from plastic strip.The intake and exhaust was made from plastic rod heated and bent around various items. Lots of trial and error. I have redone many of the parts, but I have learned many new techniques. The thermostat housing, steering box, water pump, and some linkages were carved out of pieces of plastic. One hard part is deciding how much detail is enough. On a car like this everything shows.
            Wow! I really admire what you have accomplished in regards to this model.
              Got the side bars on and painted the chassis. I test fit things this morning and just need a couple of adjustments before making things permanent. So far, so good.
ID:	1827049Click image for larger version
                The maximum possible detail, is always superior! The trick, for me, was always, to relax, and put it down. Any time, you start to become too angry, or frustrated with it! Go away, and find another way to release it. Other than just smashing it to bits? Don't mess with it! At least, not until you can calmly come back? With a realistic approach. To accomplishing what ever, your goal was? This is also true, for So many other things, in life as well!
                Mark
                S2Deluxe = (5H - C3).
                  Mark
                  The one thing I really would like to add is the carburetor linkage and accelerator mechanism, but I have no idea how to do that. I tried doing the carb linkage, but making it to scale and sturdy enough to survive is hard. You can see the foot shaped pedal in the pictures. I also need to buy some photo etch buckles and make a harness for the seat.
