R2 Avanti engine dimension needed
  • R2 Avanti engine dimension needed
    I'm wondering if anyone has an Avanti R2 engine out of the car and could measure the dimension from bottom of pan to top of carb bonnet.
    Thanks in advance for any info.
    sals54
    Uncle Sal,
    Would to the top of a R3 air box do as a measurement ?
    pb
      Sal
      The motor is sitting in the chassis, it measures approx 30 inches from the sump to the top of the air box.
      pb
      ps did I ask if you had a horn button holder for the Avanti steering wheel ?
      pb
        Thank you for the measurement. That sounds perfect. Close, but perfect. As to the horn button, no. I do have an Avanti wheel but have not decided to use it or switch to the Nardi wheel.
        sals54
          Sal
          Let me know when you decide.
          pb
            63r2 (or others),
            Could you measure the lateral distance between the front motor mounts? Trying to fit an R2 in an M5 frame.... thanks for the help!
              From the middle of the mount to the middle of the mount it is approx 18 inches
                M5 chassis might be similar to the Champ chassis in which case you could use the Champ V8 mounts.
                pb
