Fuel Stabilizer and Restorer
  • Fuel Stabilizer and Restorer
    Sounds too good to be true.
    The company (e-mail address below) below advertises that its products will restore old gasoline. The product is called PRI-G (G for gasoline.) They also have PRI-D for diesel gas)
    Has anyone used their products? Will this prevent the gummed up carburetor from old gas?
    http://www.cariboo-net.com/y2knorth/pri.html
    Paul R
    I believe most of us use Sta-Bil fuel stabilizer. It will protect fuel from getting stale, but I don't think they make any outlandish claims about RESTORING anything, and their product actually works! [^]
    I would beware of snake oil salesmen!
    Studebakers Northwest
    Ferndale, WA
      Thank you for your advice. I have used Stabil in the past, but I have several more cars that I did not, and I do not look forward to flushing out gas tanks.
      I realize the claim seems tough to believe, but then again lots of people believe in stuff they can't see.
      I was hoping to find someone who might have used it.
      By the way - how many years does Stabil work for?
      Paul
        One would think that if you knew ahead of time it was going to be 'years', it would be best to get an electric fuel pump out and suck the tank dry.
        Just thinkin' out loud....
        Paul
          Paul
          I don't know for sure, Paul, but I have three cars (1964 Studebaker Daytona hardtop; 1971 Mustang convertible; 1971 Barracuda convertible) I have now owned over 30 years each. I've only driven the Mustang 870 miles in 33 years; it turned 17,000 as I drove it home and it now has 17,869 on it. I've used Sta-bil religiously in all the cars and never had a fuel-age-related issue in any of them. BP
          Ayn Rand:
            I have used StaBil.
            Real old gasoline that has been maintained with StaBil will be better than the new style gasolines with Stabil. The new gasolines start to go bad in two to three months where the gasolines of old used to take many months up to a year or more to go bad.
            In the early '60s, I worked for a company that made fuel pump diaphrams (for Ford and others). Part of our testing was to soak the material in sour gas. At that time, you couldn't make sour gas in a few months. The fuel pumps would go bad in short order with the sour gas.
            On cars in storage, after the initial treatment of StaBil, I always add a little fresh StaBil at least once per year.
            I do NOT believe that anything can restore gasoline that has turned bad. For that, I recommend a drain and flush.
              As far as I know, you can't re-stabilize fuel after it has broken down.
              As was mentioned above, most of use use Sta-bil with a lot of success. I add Sta-bil after I fill up my gas tank in both my Studebaker and Model A Ford. I've never had a problem with the gas fowling up my carburetors. When I start the cars after their Winter's rest, they start right up.
              Rog
              '59 Lark VI Regal Hardtop
              Smithtown,NY
              Smithtown,NY
