running out of gas problem?
    Hi Jim, glad to see you here! If I remember our phone conversation correctly, this is a '58 President "J" body 2dr. Hardtop with 289 and Automatic. This year/model definitely does get a vented gas cap. If nothing else worked, check or replace it with a Stant Cap from NAPA or other "Good" Parts Store and make sure it says "VENTED"! [^]
    A wrong or clogged cap, WILL cause this condition as Ray said! [:0]
    Your parts were shipped today, thanks.
    Studebakers Northwest
    Ferndale, WA
  • Studeman
    quote:Originally posted by mnmfive
    next weekend I'm going to try blowing through the line from the front of engine into the gas tank. any other suggestions???????
    Yeah... make sure you take the gas cap off before trying to back-flush the lines. BTDT... [B)]
    Also check your gas cap- it may not be venting the tank properly as you drive. Vacuum builds up, and the fuel-pump can't overcome it.
    Ray
  • mnmfive
    Here's update: looked into the tank with flashlight, tank is extremly clean! tried to move the feed line in the tank with a rod and the feed line was solid and would not move. still run out of gas after using about 8 gallons. there are all new lines after the tank and new fuel pump. there is pressure after the pump when I take the line off. next weekend I'm going to try blowing through the line from the front of engine into the gas tank. any other suggestions???????
    Jim Rostron
  • Dan White
    I have used Gas Tank Renu on two gas tanks with very good results. If you are in S. NJ there is a franchise in Philadelphia:
    http://www.merchantcircle.com/busine...c.610-358-3277
    Dan White
    64 R1 GT
    64 R2 GT
  • Warren Webb
    If it may be just pinhole rust, I have had good results with Eastwood's tank sealer. When a friend of mine was over the house, we coated the tanks on his Sunbeam Tiger & he dripped a bit on the concrete. To this day it's still there. Wont chip off when hit with a hammer- very durable & is resistant to the newer additives mandated for air quality.
    60 Lark convertible
    61 Champ
    62 Daytona convertible
    63 G.T. R-2,4 speed
    63 Avanti (2)
    66 Daytona Sport Sedan
  • Boothguy
    How bad is the tank? Just years of crud or big holesand rust. Is the car running?
  • mnmfive
    started a topic running out of gas problem?
    I run out of gas after about using about 8 gallons. please see my update as a reply. thank everybody for responding.
    Jim Rostron
