If this is your first visit, be sure to
check out the FAQ by clicking the
link above. You will have to register
before you can post: click the register link above to proceed. To start viewing messages,
select the forum that you want to visit from the selection below.
If it may be just pinhole rust, I have had good results with Eastwood's tank sealer. When a friend of mine was over the house, we coated the tanks on his Sunbeam Tiger & he dripped a bit on the concrete. To this day it's still there. Wont chip off when hit with a hammer- very durable & is resistant to the newer additives mandated for air quality.
60 Lark convertible
61 Champ
62 Daytona convertible
63 G.T. R-2,4 speed
63 Avanti (2)
66 Daytona Sport Sedan
60 Lark convertible V-8 auto
61 Champ 1/2 ton 4 speed
62 Champ 3/4 ton auto
63 G.T. Hawk R-2,4 speed
63 Avanti (2) R-1 auto
64 Zip Van
66 Cruiser V-8 auto
Here's update: looked into the tank with flashlight, tank is extremly clean! tried to move the feed line in the tank with a rod and the feed line was solid and would not move. still run out of gas after using about 8 gallons. there are all new lines after the tank and new fuel pump. there is pressure after the pump when I take the line off. next weekend I'm going to try blowing through the line from the front of engine into the gas tank. any other suggestions???????
Hi Jim, glad to see you here! If I remember our phone conversation correctly, this is a '58 President "J" body 2dr. Hardtop with 289 and Automatic. This year/model definitely does get a vented gas cap. If nothing else worked, check or replace it with a Stant Cap from NAPA or other "Good" Parts Store and make sure it says "VENTED"! [^]
A wrong or clogged cap, WILL cause this condition as Ray said! [:0]
Your parts were shipped today, thanks.
Studebakers Northwest
Ferndale, WA
StudeRich Second Generation Stude Driver,
