What body panels interchange with 53-54 C-K?
  • #16
    I'm wondering if the larger rear valence wasn't a mid-year change. I've had a couple of relatively unmolested 53's that had the larger valence with cutout.
    Steve Hudson
    The Dalles, Oregon
    1949 "GMOBaker" 1-T Dually (workhorse)
    1953 Commander Convertible (show & go)
    1953 Champion Starliner (custom/rod project)
    1954 Champion Coupe (daily driver)
    1960 Hawk (future project?)
    Steve Hudson
    The Dalles, Oregon
    1949 \"GMOBaker\" 1-T Dually (workhorse)
    1953 "Studacudallac" (project)
    • #17
      Nate,
      Here you go....
      Its not really a gravel pan or trim panel at all. Notice it does not stick below the bottom of the rear frame crossmember. I think its really just to hide and protect the wiring for the tail lights and the license plate lights.
      Its held on with 3 bolts to the bottom rear flange on the frame member and then sticks up to form a tray for the wires. I can see why a lot of cars have been upgraded to the later style since it does look a little unfinished.
      Jeff in ND
      '53 Champion Hardtop
      Jeff in ND
      • #18
        will GT tail light shells fit a 56 C rear fender? I realize that the top of the fender trim strip is different, so will the trim and light fixture fit on a 56 hawk?
        are the GT shells side specific or interchangeable side to side
        Thanks
        • #19
          The Chassis Catalog indicates the flat gravel deflector was used on 1953 models 14G and 4H without any before or after serial number notes. Part#533578P. The curved deflector with cutout for exhaust was used in 1954 models 15G and 5H without any before or after serial number notes. Part#535135P.
          Brad Johnson,
          '56 Sky Hawk in process
          • #20
            Thanks
            You would have to build up the rear quarter panel of the 1956 to the contour of the 1962-1964 quarter panel.
