52 Gas tank needed
  • 52 Gas tank needed
    I've just found out my tank is past the point of no return. Does anyone have a lead to reproduction or nos tanks? Thank you.
    Joe
    For any car or truck?
    Parish, central NY 13131
    "It was the last chance for Studebaker to turn things around. The company was down to it's last bullet, and this new small car was it. They called it the Lark"
      Sorry people, the car is a champion coupe model 12G
      Joe
        Your definition of "the point of no return" may be different than mine. Considering the number of tanks in any condition is finite, is yours just more trouble than you want to deal with?
        You can probably find one in better condition than what you've got but, I've seen some that can only be described as partial (meaning major upper half gone), repaired and installed in show cars. If you find one, don't discard what you've got.
        '33 Rockne 10,
        '51 Commander Starlight,
        '56 Sky Hawk
          I was replacing the fuel line, when the tank cracked at the solder joint. I took it to a repair shop and they said it was rusted out. I don't agree 100% with them because there is no rust out at all on the outside, just inside. I'm taking it to a shop Thursday to see if it can be stripped and soldered.
            Joe,
            I was gonna look for you today. I think I have a couple of tanks. Condition unkown, but we might get lucky. I'll look tomorrow
            1957 President two door
              I have an old-school radiator shop here that fixes them. He built a machine that tumbles the tank with legths of chain in them. He washes, then boils the tank. He then tumbles it till he's satisfied they're clean, then cuts a hole on the top to carefully inspect the inside; then boil again. When it's perfectly shiny inside he welds the patch back in, and coats the tank inside and out with sealer. Last one he did for me was only $225.
              Maybe you can find one in your area. There's also a franchise company that has a product for this that I've yet to use. I believe it's called "Gas Tank Renu". Anyone know what I'm referring to?
                Thanks guys for the information. The place I'm taking it to is a radiator repair shop as well, so I hope it can be saved. I will let you know.
                Joe
                  If you are close to a "metal stripper" where they have the large tanks to strip paint and rust off car bodies, tehy can dip the tank, (the tank on my 52 cost me $35 to dip strip it. Came out perfectly clean inside and out. I used a sealer called Red-Kote about $25 a quart, available from the rad shop. no problems.
                  Jim
                  their Memorials!
                    Thanks again for the input. I'm stripping the tank myself with muriatic acid, available at hardware and swimming pool stores. I've used this before on a 1928 model A and it is great. The government has put an end to derusting gas tanks according to my rad man, but he told me what he'd do. I will let you know the results. Looking good so far.
                    Joe
                      Joe, I have two tanks for a '52. One's got some rust flakes rattling around inside, but it looks fairly decent spyin' thru the filler hole. The other one didn't audibly have anything rattling around in it, but I'd have to get a mirror and flashlight to inspect it for sure - same with the other one.
                      Boxing and shipping to Canada will no doubt be pricey. Contact me if you wanna pursue.
