105 in Second gear!!
  • 105 in Second gear!!
    Dunno if this link will work anywhere but AOL but this AM, this was on there: http://money.aol.com/special/30-thin...ould-come-back
    It's # 6 of 32.
    Studebaker
    "AOL User Leetalk68 Says: "I am old but my second car was a used 1955 Studebaker and it would do 105 in second and a hundred in third with overdrive."
    AOL User DRP76 Says:"Amen. We owned a '52 Champion when I was learning to drive. Lots of ahead-of-its-time features."
    With a pic of a really red 32 convertible.
    But getting back to my point...would ANY '55 REALLY go 105 in second? Even with OD?
    Musta been interesting.
    John
    Sure. Second overdrive is almost like straight third, as far as a ratio. It would be screaming, but it could have been done...with a 224 or 259 V-8, that is...I wouldn't want to push a new, longer-stroke 185 Victory Six to those RPMs![:0][)] BP
      yup, let's assume that second is about 1.7:1, OD is 0.7:1, your effective trans gear ratio is 1.19:1 (I know those numbers aren't exact; I'm handwaving) with a 3.73 rear and a 27" tall tire, a real 105 MPH is about 5800 RPM... probably not achievable with a stock cam/springs, but I'd bet the speedo read a little bit high. And if the car had a 3.54 or 3.31 (not common ratios for OD, but I suppose possible) an honest 105 would definitely have been doable. With a 3.31 and my assumptions you'd be at about 5200 RPM which is definitely believable.
        Of course, after 40 years, memories can grow hazy and tales grow larger
        Clark in San Diego
        '63 F2/Lark Standard
        www.studebakersandiego.com
          Naaaaaaaw!!
          John
