r4 engine color
  • r4 engine color
    I had an r4 built for my 51 starlight hot rod. What color should it be painted.[?][?][][]
    Red.
    JDP/Maryland
    "I'm a great believer in luck and I find the harder I work, the more I have of it."
    Thomas Jeffereson
    JDP Maryland
      Weren't the R4 blocks blue?
        You may be right, Paul Johnson's was blue, but I've seen red too. I wonder if there is a correct answer.
        JDP/Maryland
        Thomas Jeffereson
        JDP Maryland
          I don't even know for sure. It's possible that Paxton painted my engine blue for the buyer. I know the Motor Trend (?) article about building a R-4 Daytona mentioned the red engine.[?] There are so few true R-4s that it's hard to compare (Jon Myer told me one time that there were only eight R-4s actually built with "B" serial numbers).
          [img=right]http://www.frontiernet.net/~thejohnsons/Forum%20signature%20pix/R-4.JPG[/img=right][img=right]http://www.frontiernet.net/~thejohnsons/Forum%20signature%20pix/64L.JPG[/img=right][img=right]http://www.frontiernet.net/~thejohnsons/Forum%20signature%20pix/64P.jpg[/img=right][img=right]http://www.frontiernet.net/~thejohnsons/Forum%20signature%20pix/53K.jpg[/img=right]Paul Johnson, Wild and Wonderful West Virginia
          Museum R-4 engine
          1962 Gravely Model L (Studebaker-Packard serial plate)
          1972 Gravely Model 430 (Studebaker name plate, Studebaker Onan engine)
            Blue R4 ...Red R3.... (except where that is reversed[:0] A Stude thing, I suppose)
            These are NOS pic's from the SNM a few years ago....
            Here are some R3 and R4 pic's
            http://rides.webshots.com/album/4845...sdLSe?start=72
            [img][/img]
              Yes, that's Paul's R4, but the one in Motor Trend was red, go figure.
              JDP/Maryland
              Thomas Jeffereson
              JDP Maryland
                quote:Originally posted by DEEPNHOCK
                [navy][b]Blue R4 ...Red R3.... (except where that is reversed[:0] A Stude thing, I suppose)
                Wow! Great pix Jeff. When were they taken? Reason I ask is they show the supercharger belts and idler missing- stolen sometime since they were put on exhibit and before Andy Beckman took off the R-4 air filter "for safekeeping". I was also annoyed that the museum took it upon themselves to paint the oil pan black on the R-3 (was originally red).
                Ranting on- sometime after I left the engines at SNM the original Paxton crates with built in engine cradles disappeared along with the R-3 air cleaner, air tube and grommet that were with the crates.
                Museum R-4 engine
                  Paul's experience illustrates the fallacy that museums are safe environments. It is sad that valuable items would "disappear" in such a setting, but it happens. Hopefully this is in the past and those that have items on display now will not have such worries.
                    SNM during the Int'l Meet 2002.
                    Took a bunch of close up pic's to sort of document what was where, and what the little tags said.
                    All I can say is I was there with a camera
                      I had an Avanti on loan to the SNM for display that was released to someone else. I didn't even know that it had left the SNM until after the fact. The SNM official involved and the person that took my Avanti are both now deceased. I imagine that things are under much better control at the SNM now than they were a decade ago.
                        "Ranting on- sometime after I left the engines at SNM the original Paxton crates with built in engine cradles disappeared along with the R-3 air cleaner, air tube and grommet that were with the crates."
                        I'll join in that rant......I'm still trying to find a replacement for that air cleaner! So far, no luck with that so I went back to the Museum prints to get a copy of that air cleaner and having to have one reproduced. That ain't cheap!!! Oh, and the Fuel pump was also incorrect, that item had been changed out for a cheapo-repo, not original! The R3 did re-dyno in Cali. @ 333HP@ 6k and 332ft/lbs @ 4900...pretty close to advertised! The biggest issue now is to find the right color paint to touch-up the heads, that center exhaust area always burns the paint black!! Any correct color Hi-Temp paints available??
                          I had heard the early Corvette dual quad engine had the same air cleaner. Not so?
                          Bellingham, WA
                            The R-4 air cleaner was the same as used by Corvettes. The R-3 was totally different- mounted up front with a tube to the supercharger.
                            Museum R-4 engine
                              My bad. I was confused (not the first time [B)])
                              Bellingham, WA
