Rear axle measuremend
  • Rear axle measuremend
    what is the measurement across wheel mount surface ? thanks---alf
    On what?
    Tex E. Grier
      On that there ol white car I reckon...
        53-54 coupe need to change rearend
          are all stude rears same
            quote: are all stude rears same
            Yep. Any Stude Dana 44 or 27 will fit in most all others. Truck rear ends are a different width, however.
            So, could you take a Dana 44 from a '63 Lark 4 door and put it in your '53? Absolutely.
            Matthew Burnette
            Hazlehurst, GA
              52 rear axles are 1" shorter on the shaft it self.
              Jim
              their Memorials!
                I think the specific answer to your question is 55 1/2 inches. Correction, anyone?
                San antonio TX. 53 Champion Coupe, to be brought back from the dead.
                "Of course it will fit, I have a torch"
                  Thanks oldguy829. I was wondering when somebody was going to answer that question. If that is flange to flange I need to find a 9" rearend for my 56 wagon.
                    FWIW, I have an 8" from a Maverick. It is 56", fits very well.
                    Pat
                    Pat Dilling
                    Olivehurst, CA
                    Pat Dilling
                    Olivehurst, CA
                      Just slap in a Mustang with disc brakes like we did with "black lightning" that holds the Vette power!!
                        As you may know, all the stude rear ends are the same width. I don't believe you can find a 9" to fit. 58 or 59 " is she shortest (from an old hacks memory). they can be shortened, at great expense.
                        S10 rear ends late 80's to about 02 came as narrow as 54", and some (few) were posi. After chasing the same issue for a month, I went back to Stude. Just got a rearend today out of a 55 commander. It will bolt right in and it is a dana44. The posi units are available, and I don't believe too expensive, but not being a rear end specialist, I'm not sure what all needs to be changed. Be careful, as some studes had dana 27's and in the dana 44 I was told to get gears from 328? or higher and a posi would work. The tag on this one is 43/13 (330) so I think I'm on the right track. I'll let you know if I've made a mistake. don
                          thanks the lenght in inches is what i was lookink for i should have stated that from the start but i had what my friends call a " senior moment" thanks to all before i forget what the question is or was --- alf
                            One drawback to the web is the anonymity. don't know if you're talking to a class builder looking for one little bit of info, or a newb, so no offense intended. Several S10 posi rear ends on ebay. About $500 plus shipping (and they all seem to be in florida) At 54 inches, (flange to flange) theres room for adapters to a 5x4.5 bolt pattern, from the chevy 5x4.75.
                            Flange to flange on the Stude should be 55.5, but I don't have one to measure. Was hoping someone would confirm. The stude rims I have are zero offset, and the factory specs are 55.5 rear trac width, ergo.....
                              The 57-59 Ford 9" was 58" give or take a 1/2" depending on the size of the brakes. But the 57 T-Bird had a 56" wide 9". See if you could get one of those cheap. Stude rims should have about 4.3" back space for the 5 1/2" rim.
