gasket sealer... gas resistant
  • gasket sealer... gas resistant
    Are there any gas resistant sealers, Permatex, etc? I cut a gasket for the sending unit and wondered if a little sealer (gas resistant sealer) is indicated. If so , any suggestions are welcome.
    I don't know if Studebaker used any sealant on that gasket originally, but you can safely use the old style "Number 2" Permatex if you want to. It isn't affected by gasoline. Just remember to NEVER use any SILICONE sealer if it'll come into contact with gasoline.
    Dave Bonn
    Valencia, PA
    '54 Champion Starliner
      Dave Bonn
      Valencia, PA
        Are the copper washers for the screws still available?
        63VY4 Leakin' Lena Hagerstown MD
            Only at just about any hardware store you can find.
            Tom - Mulberry, FL
            1964 Studebaker Daytona - 289 4V, 4-Speed (Cost To Date: $1826.83)
            Tom - Bradenton, FL
              Tom - Mulberry, FL
              Tom - Bradenton, FL
                Why never use silicon sealer if it will com in contact with gasoline?
                    Simple, it is gasoline soluble! It does not seal gasoline, read the label.
                    Studebakers Northwest
                    Ferndale, WA
                      Ferndale, WA
                        I don't think the factory used any sealer on that gasket. It was a cork gasket, and the screws had small copper washers under the heads to seal. The "new" replacement gaskets are now neoprene (I think) just like the valve cover gaskets. Hope this helps.
                        Dan Miller
                        Atlanta, GA
                          Dan Miller
                          Atlanta, GA
                            I agree with Dave. Permatex Number 2 works well and is impervious to gasoline.
                            Rog
                            '59 Lark VI Regal Hardtop
                            Smithtown,NY
                              Rog
                              Smithtown,NY
