Strange Part Request
  • Strange Part Request
    Hello,
    This is to anyone who has restored the reel type antenna and can provide me with some advice.
    I have a reel type antenna for a 1959 Lark. Unfortunantly, the cable was cut in two, making the antenna useless at the moment. It is complete with both pieces of cable and all the other parts needed to make a good antenna.
    Does anyone have a spare cable? Is there a way to fix the broken one (i.e., sauder, weld, etc)?
    Thank you
    1947 Studebaker M-5
    1948 Studebaker Land Cruiser
    1961 Studebaker Lark 4-dr. Sedan
    1947 Studebaker M-5
    1946 Studebaker M-5
    1951 Studebaker Land Cruiser
    Do you mean the lead-in wire, or the plastic "rod" that spools the antenna mast up and down?
    I can think of no reliable way to splice the latter, but the lead-in wire can be spliced.
        Yeah, I am referring to the lead-in wire (if that is the wire that follows the entire part of the antenna). It is not plastic, so I am assuming this is it.
        Please excuse my ignorance, but what do you mean by "splicing it"
        1947 Studebaker M-5
        1947 Studebaker M-5
        1946 Studebaker M-5
          1947 Studebaker M-5
          1947 Studebaker M-5
          1946 Studebaker M-5
            Let's try again: is it the black wire that runs from the base of the antenna to the radio, or the "core" that is wound around the spool and runs up inside the antenna mast to extend/retract it?
            "Splice" is a term that means to effectively join the ends of two ropes, or cables, or wires. Properly done, a splice is nearly indistinguishable from the parent material.
            I have the guts of an old wind-up antenna around here someplace. I know power antennas I've tinkered with used a length of THICK nylon monofilament to operate the mast. Like extra-heavy weed whacker line, it is. That stuff, I don't think you could readily splice, as nylon doesn't take glue well, and is hard to weld, too.
            The lead-in wire, which plugs into the radio, can be quite easily spliced by using solder plus heat-shrink tubing.
                I don't mean to hijack this thread but it seems to go right along. Is there a way to replace the antenna that has been broken off? What about mounting hardware? Does anyone sell replacement parts?
                Back on the real (reel) topic:
                As far as the cable goes, check out your local Radio Shack.
                Carey
                Packard Hawk
                Carey
                Packard Hawk
                  Carey
                  Packard Hawk
                  Carey
                  Packard Hawk
                    I see, it is the core that is wound around the spool and makes the antenna retract and extend.
                    1947 Studebaker M-5
                    1947 Studebaker M-5
                    1946 Studebaker M-5
                      1947 Studebaker M-5
                      1947 Studebaker M-5
                      1946 Studebaker M-5
                        My antennas (1951 & 1953) have cables like piano wire, not nylon. Maybe the later ones are different; I don't know
                        If it's spring steel cable, is it broken in halves or broken near the mast? Those antennas extend about 5 1/2 feet. If the break is near the mast, the remnant in the mast can be carefully drilled out. Then clean, flux and solder the cable back in to the mast. Maybe it will only extend five feet but that's twice as long as other antennas.
                        If the broken cable is too short to be serviceable, you'll need to find a replacement.
                        '33 Rockne 10,
                        '51 Commander Starlight,
                        '56 Sky Hawk
                          '33 Rockne 10,
                          '56 Sky Hawk
                            It will probably need to be replaced as it seems to be right in the middle of the cable. Do you know anyone who would have a spare laying around?
                            1947 Studebaker M-5
                            1947 Studebaker M-5
                            1946 Studebaker M-5
                              1947 Studebaker M-5
                              1947 Studebaker M-5
                              1946 Studebaker M-5
