Wheel and Tire Advice, Anyone?
  • Wheel and Tire Advice, Anyone?
    I just purchased a 1956 Studebaker 1-ton truck. It has the old split rims and bias ply tires. I'd like to replace both the rims and tires. I'm not finding a lot of good information on where to go or who to use, though I've been searching since I purchased it two weeks ago. My local tire shop doesn't even want to touch the tires/rims. Oh, it has a dually on the rear, that is also making the search interesting. Thanks in advance for your advice, suggestions, comments.
    Are these 16 inch rims? You might try Stockton or some other aftermarket supplier and also placing a post on Studebaker Truck Talk (http://www.network54.com/Forum/23885/).
    http://community.webshots.com/user/GuidoSalvage
        I thought I saw a Toyota or Nissan 1-ton dually with huge five lug pattern, reminded me of the one on my 49 Stude 2-ton.
            I have never had a 56. I had a 47 one ton but I think the lug pattern was different. Do you have 5 lugs or what? duals on rear? What size wheels? 16,20 or something else.
            Tex in Alabama
            53 C coupe
            Tex E. Grier
              Tex in Alabama
              53 C coupe
              Tex E. Grier
                Truegrace - Where are you located? This doesn't happen to be a '56 1 Ton that came from the BC Interior did it?
                <h5>Mark
                '57 Transtar
                3E-6/7-122
                </h5>
                Mark Hayden
                '66 Commander
                Zone Coordinator
                Pacific Can-Am Zone
                  <h5>Mark
                  '57 Transtar
                  3E-6/7-122
                  </h5>
                  Mark Hayden
                  '66 Commander
                  Zone Coordinator
                  Pacific Can-Am Zone
                    They are 16" split rims. There are duallies in the rear. The lug pattern is 6 bolt with 7 1/4 bolt spacing.
                    We are located in Sierra Vista, AZ. The truck came from Phoenix area a few weeks ago.
                        I have heard that International 1 Ton Trucks had the same wheel with one piece rims, if you have an old Truck wrecking yard near you.
                        Studebakers Northwest
                        Ferndale, WA
                          Ferndale, WA
                            Sounds like 5 lug Bud wheels with 8" bolt circle which I believe were common on most makes of one ton trucks till around late 60's.
                            Should use 1 1/2" wrench size lug nuts.
