Hubcaps for a ‘62 Hawk
  • Hubcaps for a ‘62 Hawk
    Have 15” Ford steel wheels that I want to replace wire wheels for, now I need hubcaps, any ideas?Click image for larger version
ID:	1760507Click image for larger version
    How about 62 GT Hawk wheel discs or Avanti?
    Originally posted by San Diego Ron View Post
    Have 15” Ford steel wheels that I want to replace wire wheels for, now I need hubcaps, any ideas?[ATTACH=CONFIG]80883[/ATTACH][ATTACH=CONFIG]80884[/ATTACH]
    1950 Champion Convertible
    1950 Champion 4Dr
    1955 President 2 Dr Hardtop
    1957 Thunderbird
      '59-'63 used the same wheel covers, they were just trimmed in different colors for different years and models, so they shouldn't be too hard to find. You can get repops for around $75 each, but used will be less. Sticker kits to replace the paint (usually gone by now) are available on Ebay for around $30 for a set of covers worth.
      Or you can spend a tedious 45 minutes per cover to tape and paint them like I did (before I discovered the stickers).
      Here are my repainted '62 covers.
        Wheel Covers should fit the Ford Wheels, but if it is "Hub Caps" you are wanting, no Studebaker Hub Cap will fit Ford Wheels.
          Okay, good to know, I need wheel covers, not hub caps and Studebaker is the only way to go. And thanks bensherb, after seeing how good the ones you have, know that is the way I must go. The wire wheels look good but after lug nuts worked loose on one wheel destroying threads on lugs, just don’t trust them driving on freeway. Thanks Guys, the hunt is on.
