Re: 55 commander, 2 dr sedan, 16 G8F4, Paint or not and what color
  • Re: 55 commander, 2 dr sedan, 16 G8F4, Paint or not and what color
    I suspect there may be no standard but here are my questions. Paint items like drive shafts, tie rods, clutch operating shaft, differential, etc.
    I understand the engine, clutch housing and transmission were all one color. Original engine was painted blue. I'm thinking everything else black. Engine compartment same as lower body color. In my case yellow.
    Thoughts?
    Thanks
    Merwin Harstad
    Yes, that sounds correct, I would describe almost everything on the Chassis as Semi Gloss Black.
    The underside of the bodies were Exterior Body Color usually with Tar based undercoating over that.
    The '55 Power Train's were a "Special" shade of Dark Blue with only a touch of Green, called Alberta Blue available at Studebaker Vendors.
    http://studebakervendors.com
      Valve covers should be silver, with Sweepstakes decal, if memory serves me correctly.
        Just out of curiosity, if a '55 Commander was equipped with a 259 with a 4 barrel, would the engine have then be called a Passmaster and the valve covers painted gold?
        American iron, real old school
        With two tone paint, it sure is cool
        Its got 8 cylinders and uses them all
        With an overdrive that just won't stall
        With a 4 barrel carb and dual exhausts
        With 4.23 gears it can really get lost
        Its got safety belts and I ain't scared
        The brakes are good and the tires are fair.
        Tried to sell her, but got no taker
        I"ll just keep driving my Studebaker
          No, still Silver, only a President "P" Code 259 was Gold.
          I think the Late 1955 259 Commander "Bearcat" 2 Brl. becomes a "Wildcat" with the 4 Brl. !
