I've used this company before. They'll build the cables to whatever spec you want. Cheap, fast, and high quality. Cables for my 6 volt '55 Commander came out to about $12 each and I had them within a week. If they're good enough for a boat, they'll last forever on a car.
http://www.bestboatwire.com/custom-c...cable-assembly
Found a Good Source for Battery Cables
Originally posted by rusty65 View PostI had to go through the archives here,but I used CustomBatteryCables.com out of Arizona.They were a bit pricey but they are the real deal.I bought them about 8 years ago so I don't know if they're still in business.
https://www.custombatterycables.com/...nal-kit-03-07/
That is strange that they don't use the lead battery terminal for the positive.
At least I was able to find a nice original ground cable at the junk yard.
Originally posted by TWChamp View Post/Cut/The battery lug is negative, and you can order the cable size and length, as well as the relay terminal size. I ordered the 2 gauge 30" with 5/16" terminal for my 1950 Land Cruiser./Cut/
https://www.ebay.com/itm/Battery-Cab....c100005.m1851
Someone put a very thin and long 12 volt battery cable on my car before I bought it, so I removed it and put on a 36 inch 00 cable that I bought from the junk yard. Research tells me the correct cable is 30 inches and 2 gauge, so that's what I'll install. I see no point in overkill.
I use McMaster Carr. The have 2/0 available with many lengths and ends. 2/0 is much larger than 2 ga
In future, try any forklift supply house. You should see the size of the battery cables on my 36 volt forklift.
I purchased some bulk 1/0 welding cable and some appropriate ends and had them crimped on at my local battery shop.
After having no response to my wanted list I posted back in July, and having no luck finding good original battery cables in the junk yards, I finally found this outfit on ebay. The battery lug is negative, and you can order the cable size and length, as well as the relay terminal size. I ordered the 2 gauge 30" with 5/16" terminal for my 1950 Land Cruiser. It's the closest thing I could find to original. I was surprised that SI doesn't sell battery cables.
https://www.ebay.com/itm/Battery-Cab...72.m2749.l2649Tags: None
