Found a Good Source for Battery Cables
  • Found a Good Source for Battery Cables
    After having no response to my wanted list I posted back in July, and having no luck finding good original battery cables in the junk yards, I finally found this outfit on ebay. The battery lug is negative, and you can order the cable size and length, as well as the relay terminal size. I ordered the 2 gauge 30" with 5/16" terminal for my 1950 Land Cruiser. It's the closest thing I could find to original. I was surprised that SI doesn't sell battery cables.
    https://www.ebay.com/itm/Battery-Cab...72.m2749.l2649
    I purchased some bulk 1/0 welding cable and some appropriate ends and had them crimped on at my local battery shop.
      In future, try any forklift supply house. You should see the size of the battery cables on my 36 volt forklift.
      sals54
        I got mine at tractor supply
        y
          I use McMaster Carr. The have 2/0 available with many lengths and ends. 2/0 is much larger than 2 ga
            Someone put a very thin and long 12 volt battery cable on my car before I bought it, so I removed it and put on a 36 inch 00 cable that I bought from the junk yard. Research tells me the correct cable is 30 inches and 2 gauge, so that's what I'll install. I see no point in overkill.
              Originally posted by TWChamp View Post
              /Cut/The battery lug is negative, and you can order the cable size and length, as well as the relay terminal size. I ordered the 2 gauge 30" with 5/16" terminal for my 1950 Land Cruiser./Cut/
              That looks good for the Negative, but Positive Posts are Larger and their Positive one has way too thin a Battery Terminal:
              https://www.ebay.com/itm/Battery-Cab....c100005.m1851
                That is strange that they don't use the lead battery terminal for the positive.
                At least I was able to find a nice original ground cable at the junk yard.
                  I had to go through the archives here,but I used CustomBatteryCables.com out of Arizona.They were a bit pricey but they are the real deal.I bought them about 8 years ago so I don't know if they're still in business.
                    $321.25 for a Dodge battery cable kit. I must be missing something here, or the cables are made from gold.
                    https://www.custombatterycables.com/...nal-kit-03-07/
                      I've used this company before. They'll build the cables to whatever spec you want. Cheap, fast, and high quality. Cables for my 6 volt '55 Commander came out to about $12 each and I had them within a week. If they're good enough for a boat, they'll last forever on a car.
                      http://www.bestboatwire.com/custom-c...cable-assembly
