My Half A$$ Studebaker Rebuild
Originally posted by bensherb View Post
Originally posted by Topper2011 View Post
Rick, yes, but it seems the new trunk floor doesn't have the depression low enough to reuse the stock bracket. it could also be where I ended up welding it as well. i could probably see if I can remake the reinforcement like the original floor pan.
Oh, ok. As long as the tank doesn't hang too low and sits relitively level, I wouldn't worry about it either. As long as the reinforcement in the floor is suffucient to carry the weight of a full tank, I'd make a longer mount as you suggested. It seems odd that the left sid mounts would be ok but the right side one is 2" too short.
I went on a little trip yesterday.
The burned hillsides of Highway 152 the firefighters worked so hard to put out.
Fellow SDC member wanted to have this car hauled off. As others have said, there are definitely bodies out there that are better than mine. This was one of them.
It's all mine now, well except the roof.
- 2 likes
You should have said something Roland, I have a trailer, could have hauled it in one piece. If you use the (in my opinion ugly) '63 side grills, you'll need to use the '63 hood too. They are different where they meet the grills. I'm not a fan of the mods they made to the '63/'64 side grills and headlight rings, I do however prefer the later main grill screen to the '62 one and like the '63 rear grill better too. And the '64 hood ornamet is just cool!sigpic
Originally posted by bensherb View PostYou should have said something Roland, I have a trailer, could have hauled it in one piece. If you use the (in my opinion ugly) '63 side grills, you'll need to use the '63 hood too. They are different where they meet the grills. I'm not a fan of the mods they made to the '63/'64 side grills and headlight rings, I do however prefer the later main grill screen to the '62 one and like the '63 rear grill better too. And the '64 hood ornamet is just cool!
The new parts I picked up is already paying for itself.
I was wondering how I was going to make the right side fuel tank reinforcement plate, but the "new" trunk floor had a good one.
This is where I have to massage the floor to the depth to accommodate the plate. I mounted the tank and marked the underside and drilled the hole for the mount.
Took some pounding to fit the plate, but it's done.
Trial fit and it looks like it fits and even able to use the original bracket for this side. I was off on drilling the hole, but you can "clock" the bracket for different reach.
- 1 like
The wiring harness for the rear lights needed new tape, so I replaced the Elliot tape with new.
I wanted to reroute the tail harness back in it's place.
Now I can put the trunk lid back on for more body work.
I put the hinges in the down position, placed the trunk lid, then bolted the lid to the hinges from the inside of the trunk. It was just manageable for me by myself.
- 1 like
Had to go out to ACE hardware for some fender washers for the fuel tank. The ones I bought on Friday disappeared somewhere in my garage.
I also got some shims for the trunk lid.
Fuel sender installed and taped the wire to hold it in place as it plugs in near the license plate lamp. With my replacement-replacement washers, I installed the tank.
This is the fuel filler neck and I don't have a sand blaster, but I do have Evaporust!
I didn't want to waste all of my Evaporust, so I sealed the ends.
I'll let it marinade over night and then flip it over.
- 1 like
