My Half A$$ Studebaker Rebuild
    Looking GOOD; and your 3 point turn kinda reminds me of that Ferrari footage from a couple of weeks ago!
    With the camera, manual steering, no driver's door, three speed and two cars that are never there, I was busier than a one legged man in an ass kicking contest!
    • yeah, I'm thinking that R2 would have a JT in the serial#
      • Worked on getting this aftermarket ignition switch mounted instead of flopping around having to use two hands to start the car.
        Using the motorcycle front sprocket lock washer, I modified the teeth enough to get the ignition switch held in place.
        Click image for larger version  Name:	PA120834.JPG Views:	0 Size:	69.9 KB ID:	1806390
        The teeth are bent so they grip the back of the fiberglass dash opening to keep the switch from spinning.
        Click image for larger version  Name:	PA120832.JPG Views:	0 Size:	82.2 KB ID:	1806392
        I think I need to flatten the washer a bit more as the locking nut sticks out too far, not flush. For now, I can work with it so I can drive the car out before I set it and my garage on fire from it shorting out on something.
        • The exhaust heat valve didn't even remotely seem like it was opening. At the risk of having cold running problems or the choke not coming off soon enough, I took it out.
          I put some MAPP gas heat on it to test it.
          It does work, just didn't seem to be on my car.
          I put in a spacer I had from the wrong header pipes.
          Exhaust is very even now and with our mild winters, it shouldn't be a problem.
          • This was posted on my thread in my motorcycle forum
            Chickasha Fall Swap Meet
            • Comment
              • Merry Christmas everyone!
                • Since everyone wanted to sleep in, I wanted to be a little productive. My fittings came in for the oil filter bracket.
                  I removed the toilet filter canister to make some room and clean up the engine compartment.
                  I wanted to clear this spot for the future a/c unit.
                  It literally took me a couple of hour to mount this as I had to bend the lines to fit my application, much shorter than the previous owner's car.
                  Not the most elegant job, but it's done.
                  • I think it runs just a bit better than the first video I posted.
                    • Had some time in yesterday morning to finally pull off the lower trim to the rocker panel.
                      Glad I bought those spare ones.
                      • https://www.hemmings.com/blog/2020/0...useum-is-here/
                        • It's been awhile since I've worked on the car. It's been cold and rainy and I've been lazy, but did do a bit.
                          My floor pan equipment, thanks to Craigslist free ad and Costco.
                          Chalking out the floor to be removed
                          My Costco supplied tracing paper.
                          Waiting on the new blades for my eBay metal shears to start cutting the floor.​
                          • The eBay metal shear needed new blades and I also got them on eBay.
                            These fit a number of shears.
                            Wow! This cuts like butter. I don't think the die grinder, rip saw or air saw could have cut this 18ga sheet faster or cleaner. Everyone that works metal should have one of these.
                            Total cut time, about a minute.
ID:	1818090 Wanted to try out the new welder on the 18ga to see what setting I should be on.
                              Still using the flux core for now. Hoping it will be cleaner with the gas. Bad news that my new Lincoln helmet isn't working right, so I went back to my cheap Century.
                              • Roland, you will love using the gas with the MIG. It makes sooooo much cleaner welds!
                                Paul
                                Winston-Salem, NC
