My Half A$$ Studebaker Rebuild
  • I never had any problem with the flex fan, it worked well and cooling was fine. I put it on after I mangled the stock fan when it tore into the shroud when I broke an engine mount. The main reason I went to the electric fan was to eliminate the massive fan shroud. It made it impossible to do anything at the front of the engine without removing it. At least I made it two piece so I only had to remove the top half. I've had that shroud off and on more times than I care to count. You'll see when you go to bolt that fan on with it in the way.
    Actually the way to do it is to install the fan, slide the shroud over it, then install the radiator, then bring the shroud to the radiator and bolt it up.
    • Originally posted by bensherb View Post
      Yes, I found that out the hard way. Remove the bolts to the shroud, push back towards the engine, remove fan, then remove shroud. I am trying to see if I can run the generator, so I don't think the charging will be sufficient for the cooling fans since they like to come on at low idle or beep and creep traffic.
      • Well, I had a small bike ride with the club that ended up fetching the stalled bike on a side street a mile away from the starting point.
        It was quite a turn out and we took off in a flurry of smoke and sound. The fury of angry bees going down the street was intoxicating until Cal had to pull off, his bike had stalled. I pulled over to see if he could restart and my bike was idling happily until it didn't. I tried restarting it, but I only have so many kicks in me and gave up. I realize I had forgotten to take my tools as this bike tends to foul the plugs with the oil injection. Good thing we were only a mile into our ride and Cal and I walked back to fetch the trucks and load the bikes back up. Tired and hot, we decided why not get lunch! Good answer.
        Since I try not to waste my weekend, progress on the Hawk is needed. The service manual doesn't mention sealer between the housing and backing plate, so it would seem a good idea to throw some 3M gasket sealer in there to keep the grease from making a mess and water out. I could be wrong, but it can't hurt either.
        You know, Studebaker gets a bad rap considered being a "cheap" car. Even my dad told me they were bad cars. He liked Chevys. I was admiring the detail of this rear brake when I was reassembling it. There are stops on the lands the shoes ride on that prevent the shoes from moving all over the place. Also, the plate that rides between the tops of the shoes help with the self energizing effect and relocating center. Even the delicate spring on the parking brake crossbar to help center the bar on the rear shoe. None of the drum brakes Ive worked on had these features. Each of these costs money, so Studebaker made some investments in their products. I'm impressed.
        I put the heater back in so I can run the hoses. I'm having a heck of a time finding tension clamps for the heater hoses as they measure the clamps as actual size, not for the intended hose size.I hate the stainless worm clamps and the constant tension clamps are better for your car. Anyone with modern plastic tank cars, reuse your factory clamps, the worm type have a pressure point under the screw area and can crack your radiator outlet. Unfortunately, newer hoses are thinner than the original, so you cannot use the wire spring clamps on them.
        • I enjoy reading about your progress and assorted other things.
          You wouldn't have been too warm here. It was 43 degrees F and raining when I came home from a firehouse breakfast this morning (about 10AM).
          I have had a Chevrolet spindle sheer off on an Interstate highway, but I have never had a Studebaker spindle sheer, or remember ever working on one that did.
          • [QUOTE=Topper2011;1157133]Well, I had a small bike ride with the club that ended up fetching the stalled bike on a side street a mile away from the starting point.
            Was that a CJMC "small bike scramble" ? I took my Yamaha YSR50 on one, over Mt Hamilton a couple years ago, last year I took my Honda CM200, yea, they limit size at 175cc but they said it was fine, "just don't run anyone down". Honestly, I had more trouble not running the others down when on the YSR. With riding to the starting point, on the ride and the trip home, the 170 mile trip was a long day for either the 50 or 200 but it was a heck of a lot of fun, especially the ride with 40 other tiny bikes.
            • Originally posted by Topper2011 View Post
              [ATTACH=CONFIG]80951[/ATTACH]
              [ATTACH=CONFIG]80952[/ATTACH]
              [FONT=Tahoma]
              Check your PMs.
              60V-L6 - 60 Lark convertible
              • [QUOTE=bensherb;1157175]
                [ATTACH=CONFIG]80949[/ATTACH]quote]
                Yes, this was the Livermore Small bike this time. Now that I think of it, I think I've seen you on the ride last year, around September? I was riding the TS100 that got a flat 4 miles from The Junction. We went from San Jose over Mt Hamilton and to the Junction for lunch and then return the same way. Really a fun ride, without the flat tire of course.
                • Yep, on that ride I continue on over to Livermore from the junction, since I live on that side of the hill. Too bad I didn't know it was was on the 11th, I had no plans that day. Probably still wouldn't have made the ride though, my small bikes are currently in Goleta. Smallest I have here currently is a 650, but I usually ride my 883.
                    We have that one in the second saturday of September. Maybe I'll see you there and we can talk bikes and Studebakers.
                    • Well, being that I'm dealing with my axle issues, I moved on.
                      My Elliot tape came, so now I can finish up the heater motor.
                      Now, I've just got to install the ducting, which Carl said to heat up in boiling water to slip them on. Still need to get the 4" clamps, maybe Home Depot.
                      Look what I scored! Please note: Jeep wheels DO NOT fit my car. The tires hit the tie rods. The back space is too deep for my car. These have a 3.66" back space and the Jeep wheels are over 4.5". Now I have to break down the tires and run them on black wall out. I'm still happy with these new wheels that were on a 63 Falcon.
                        [ATTACH=CONFIG]81083[/ATTACH]
                        Good choice.
                        Jerry Forrester
                        Forrester's Chrome
                        Douglasville, Georgia
                        • Originally posted by Jerry Forrester View Post
                          Good choice.
                          Thanks Jerry. I've been cruising CL for quite awhile looking for these.
                            I'll bet you got a good deal on them.
                            I'm still looking for a deal on a pair of 'Old Styles' 15X7's to go on the front of Buttercup. Summit sells new ones for $123 each. They're almost an exact copy of the originals with just a few small differences. The ones on Buttercup in my Sig pic are 14X7's. They are now on my swap meet trailer.
                            Jerry Forrester
                            Forrester's Chrome
                            • Due to being on vacation for two weeks and overtime for two weeks, I finally had some time to work on the Hawk. Finally think I may have a handle on my axle bearing issue, so I buttoned everything up.
                              Finished the brake lines as well.
                              Father's Day I was able to find a tire shop open and swapped over the tires onto the Torque Thrust.
                              I really like the look. This is what it's going to look like since the jack stands are under the axles, it's the height it's going to be. I've never liked the dragging' ass look anyway.
                              • I was able to put a couple hours into the GT after work today.
                                Loosely installed the blower after heating up the duct in the hot sun.
                                The heater end was a pain to install, but it's on.
                                I had bought 10ft of hater hose and ran out before I finished. I still need about 5ft more for the heater valve to the elements. I went with spring tension clamps since I hate the look of the worm type. That was an adventure! I don't know how many various hose clamps I ordered and returned to get enough tension on the thin 5/8" hose, weeks of delay.
