My Half A$$ Studebaker Rebuild
More ugliness.
This came out of the pocket between the pinion bearings. Looks like a shim, but I'm getting ahead of myself.
Youtube is a wealth of knowledge and I learned that the Dana 44 had been marked on the caps so you cannot mix them up. Note the location and position of the K for each side.
Carrier came out way too be right.
Not much preload on the pinion bearings either.
Traction loc is a generic term, usually Chrysler/Mopar specific. I have rebuile Studebaker twin traction carriers using mopar traction loc parts. Some even had the 19 spline gears.Bez Auto Alchemy
Originally posted by bezhawk View PostTraction loc is a generic term, usually Chrysler/Mopar specific. I have rebuile Studebaker twin traction carriers using mopar traction loc parts. Some even had the 19 spline gears.
Oops, I should have said "Twin Traction", also probably a generic term for Studebaker. I moved onto the master cylinder/Turner install kit.
I removed the front brake residual valve out of the AMC master. The rear one won't make a difference, even by adding another one down the line, from what I've read.
I pulled the brass flare fitting with a screw.
When it comes to bench bleeding without a residual valve, it takes blocking the hole with your finger to keep the return stroke from sucking air right back in.
Bled and capped off so I can install it without making even more of a mess.
Instructions indicate another hole needs to be drilled into the floor for access to the other reservoir that would otherwise be covered. They even provide a plug to cover the hole.
Fitting the master was close, but Jim Turner did a fine job of getting it just right.
The pedal brace hits the new master, so I had to "modify" it.
Clearance is so close, the bolt doesn't sit right either.
So it gets the die grinder.
So it's finally in and while not the greatest access, I can fill both reservoirs with a funnel. Brake lines are next and once done, I can finally start reinstalling the transmission.Last edited by Topper2011; 01-20-2019, 04:59 AM.
Originally posted by bezhawk View PostTraction loc is a generic term, usually Chrysler/Mopar specific. I have rebuile Studebaker twin traction carriers using mopar traction loc parts. Some even had the 19 spline gears.Gary L.
Seeing as how my differential is beat, does anyone know if any Dana 44 carrier will fit? I'm looking at this one.
https://shop.broncograveyard.com/D44...uctinfo/22094/
I suppose axle spline count would be different.
