looking for NOS or very good condition Stewart Warner Temperature Gauge for 57 GH
  • looking for NOS or very good condition Stewart Warner Temperature Gauge for 57 GH
    Hello together,
    I am looking for a NOS or very good condition Stewart Warner Temperature Gauge for my 1957 Studebaker Golden Hawk.
    part number according to the book is 1539879.
Name:	temperature gauge.jpg
    Really appreciate any leads in finding a working one.
    Thank you very much.
    Best regards
    Rudy
    I found this with a: "Studebaker 1539879" Google Search!
    Also a lot of "Sold" listings on eBay and Stude. Websites.
    http://mystudebaker.com/electric/studebaker-gauges/
      I'll look at my stash, I may have one but no glass. I know I had it in hand when gathering Dads GH parts, but may have not kept it as mine works fine..
      sigpic1957 Goldenhawk
      Keeping the passion alive
        Since the CORES are worth $75.00, and rebuilt $175.00 PLUS Core, that may help someone!
          Rich, the ones we have are NOS. The core charge is in hopes of having used ones rebuilt when the NOS ones are sold out.
            First of all , are you sure your gauge is bad.
            It could be the sender or a ground problem.
            Sometimes mechanics use teflon thread tape and the temperature senders not properly grounded.The senders themselves are also subject to failure.
            I also found one car that had the wrong sender installed.
            Before you spend $175.00 check out the whole system.
            Robert Kapteyn
              Hello all
              Thank you very much for your help. I already replaced temperature sending unit and it did not work.
              Best regards
              Rudy
                Hello Matthew, I sent you a PM. Thank you. Rudy
                  Hello together,
                  Today I installed a NOS temperature gauge. Unfortunately it also doesn't work as it should. As soon as I turn the ignition switch to the first position, after about 3 seconds, the gauge's needle starts to move to the right (slowly, but steady), until it reaches over 240°F. And there it stays forever. When I shut the car off (ignition switch tilted, no current), then after a while the needle does move back to the left side, until it reaches 100°F.
                  It doesn't show the correct temperature of the coolant. My engine was still cold, when it showed this behaviour.
                  I also checked the temperature sender, which seems to be the 1957 style. I have also a NOS 1957 temperature sending unit, but I couldn't manage to remove the old temperature sender, seems to be rusted-in. I also unplugged the wire and plugged it in again. It doesn't solve the problem.
                  But before I remove the temperature sender (which is very hard to remove, cause it is rusted-in), I would like to rule out other causes of this problem.
                  This even happens, when I remove the wire that attaches on the back of the temperature gauge..
                  Does somebody have an idea what causes the needle to move to the far right, just after turning the ignition on (this starts after 3 seconds to move to the far right position of the temperature gauge).
                  Thank you very much for any ideas.
                  Best regards
                  Rudy
                    https://redlinegaugeworks.com/
                    You can try these folks. They’ve done work for me in the past. They’re working in my gauges from a 63 Hawk. Shannon is the guy I work with.
