LED Dash Lights?
  • LED Dash Lights?
    Anyone know if there is a source for LED bulbs to replace the old filamnet bulbs in dashboards?
    yes, you might try this site: http://superbrightleds.com/led_prods.htm
    they indicate 12v - I'm sure someone could rig up 6v, if needed.
    --george
      --george
        I dunno if LEDs will work well in the stock Studebaker gauges as they use indirect lighting and LEDs are very directional. Worth a try though if you already have some around.
        I have not had good results with any LEDs I have tried in automotive applications - did not work well as dash lights in the Porsche (although a purpose-made LED conversion is in there now and works great) nor did the 1157-replacement LED "bulbs" provide any more light than regular 1034s in my taillights - exactly the opposite. Again, I suspect a purpose-made LED conversion with a whole array of LEDs in a breadboard the approximate size of the taillight would work better.
            I bought my 50 Starlight from Dave Carter four years ago. Dave had tried to get more
            illumination in the dash numerals by using blue LED's ---with no success. He wrote an article on the experiments. The numerals were so dim they were hardly useful for night driving. I modified 6 volt Krypton flashlight bulbs by silver soldering on a pair of bosses to index with the former #55 bulb sockets. Fixed it -glows like the devil now.
            ...Dick Curtis
            The 1950 Champion Starlight
            Santa Barbara
            CA
              ...Dick Curtis
              Santa Barbara
              CA
                My "former" 53 Champion 2 door sedan, was also a project of
                David Carter and David had put the blue LED's in "Charlene",
                as well, and they were OK!
                glen Brose - Perkinsville, AZ
                    Check out your sources to see if they can be dimmed.
                    Most can't, and are either on or off.
