Now WTF???
  • Now WTF???
    So there i was happily detailing the engine bay, getting rid of all the grime form being in the shop for so long, being extra careful not to dislodge or disturb anything, and I notice this blue wire with a clip on the end, coming out of a bundle of wires, just hanging there. As it's only a few inches long, there's only so many places it can reach, including through a hole in the firewall where it can be reached. looked under the dash and didn't see anything which would hold a clip without one attached. Also, the temp gauge wasn't working at all, and I saw some water on the frame below the water pump which was replaced. now, one of the reasons the engine failed was because it wasn't hooked up properly, but I felt (couldn't see) the back of it and it felt secure. Is this a coincidence? Is God punishing me for enjoying my car so much?
    peter lee
    Might be, but it deep-ends on the kind of god being around at that moment...
    Josephine
    -55
    Champion V8
    4d sedan
      Define a Blue Wire with a "CLIP"?
      Usually correct or Factory wire ends are a Round Bullet connector, Male or Female, or a Flat Spade Type connector Male or Female.
      OR, a "CLIP" is usually a Temporary Alligator "Clip".
        If it is a short wire, close to the firewall, perhaps it goes to the coolant sending unit. Some of these, instead of an "eyelet" type connector that is fastened to a threaded post with a nut...instead was a flat ended stud with a clip style wire connector that merely slid onto the sending unit. Check it out.
          Keldoran God of Cars
          http://fictspedia.wikia.com/wiki/Keldoran_God_of_Cars
          "Every man I meet on the street is superior to me in some respect, and from that I can learn."
          R.W. Emerson
            Which side of firewall? Lt side or drivers is where your temp sending unit wire should be close to the fire wall. Sending unit should be at the back of the Lt head on a 289.
              Is this a retorical question, or are you expecting help to figure out what this wire is?
              If you need help, then the make, year, model, and equipment of the car might assist us in helping you. Even better would be a picture of this wire and clip...............
              Paul
              Winston-Salem, NC
                Sometimes, if the car has an automatic transmission, the wiring harness has what appears to be an extra wire that went to the overdrive, if the car had been so equipped.
                But I agree with the request for information on what the car is.
                60V-L6 - 60 Lark convertible
                  The temp sender on my '61 Hawk has a "clip", but the wire is orange. - Jim
                    When I read "clip" I think of alligator clip. What type of terminal is on the end of the wire?
                    Also need the information as mentioned above.
                      That sounds right. Now where is the cooling sending unit located?
                      peter lee
                        Er...I too have sometimes not read posts closely.
                          It looks like the type of clip used to connect speaker wires.
                          peter lee
                            OK...I found this "on the net"... I think I have one like this on my '60 Lark.
                              Coolant temp sensor is generally located on the back of one head.
