Why it wouldn't run. ;)
  • #16
    Gm used that type gen/pump setup in the mid 50s or there about.
    • #17
      Is that the throttle linkage attached to the choke ? Also, where does the coil wire go that should be in the center of the distributor ? Looks like a regular plug wire.
      • #18
        Originally posted by Skinnys Garage View Post
        Do you think the 6V coil is the issue?
        Bingo! There are other problems, but I bet the "mechanic" who they had working on this truck went to his FLAPS and they gave him a coil for a stock 52 Studebaker truck because that's what the computer said.
        • #19
          I don't think that would stop it from running.
          But I do think the missing fuel line and the missing accelerator pump may have something to do with it.
          Plus that huge vacuum leak at the right front carburetor bolt.
          Jerry Forrester
          Forrester's Chrome
          Douglasville, Georgia
          • #20
            I wasn't sure if the 6 volt coil would have kept it from running, but it couldn't have been good. It is more of an indication that their mechanic was not careful. The truck was running and driving when the owners became unable to drive any more. The carburetor should not have required replacing. I got a disassembled carb with the truck that I think was the one originally run on it.
            • #21
              I hope you guys have enjoyed this little game. I could have just posted a picture and comment about the 6 volt coil, but I thought this was more fun. Now I have to get this thing running so I can take my granddaughter for a ride....if I can get the controls back.
              • #22
                AND DO IT SOON! If you are like me, you realize how fleeting the time is when a child is this young and time is so precious. It won't be long before this little girl has a little one of her own and you are left clinging to the memories.
                By the way, some of the best pics on the forum of recent...
                • #23
                  She's just turned 3 and stays with us every day during the week. I'll keep her exposed to Studebakers.
                  • #24
                    I am curious about the electrical system in the truck. Has the truck been converted to 12 volts? Is the truck 6 volts and the engine 12 volts? The 55 259s were 6 volts then 12 volts thereafter. I have a 63 259 in my 54 sedan and it starts and runs on 6 volts. Your 6 volt coil and ballast resistor caught my eye at first. I had to ask myself is the engine running on 6 volts, first question, then why is there a ballast resistor and then I noticed a 12 volt battery. This all confused me, as a 52 should be 6 volts but the engine was 12 volts. Could you explain the electrical system in the truck.
                    • #25
                      Yes it has been converted to 12 volts. I am not impressed by some of the wiring, but I will replace it all.
                      • #26
                        I remember actually seeing a '58 Golden Hawk that was factory equipped with a generator/power steering pump and air conditioning. There just wasn't enough room under the hood for an air conditioning compressor along with power steering and a supercharger so Studebaker used them to solve the space problem.
                        • #27
                          You will find that this Top Half is stamped by the Fuel Inlet as 6-125 or 6-127 which is the High Choke '59-'60 Stude. Stromberg WW for the "Clamp on" Air Cleaner.
                          The bottom Half of the "Spare" is a '63 6-130, or 6-132 which is a '64, WITH the PCV Fitting (Tube) in the Rear, it's Top would have a Stud fastener for the Air Cleaner, they are NOT compatible.
                          With the Carb. on the Truck, you might have one complete one!
                          • #28
                            I'll have to do more digging in the spare parts bins. I know we have older 2 barrel carbs and I have an AFB or WCFB available if I want to change intakes. Right now I just want to get it running and see what I've got.
                            • #29
                              To me, it looks like your truck is still sporting the original 6-volt battery box. When the V8's came along, they used a higher sitting battery box to give better clearance by the valve cover. I'm thinking you could probably make one using some angle iron and a little ingenuity. If you have access to a V8 C-cab truck, take a good look at the battery box, how it's built & located. I know it is nothing critical to your current concern (getting it running), but just a little suggestion to consider when you have time to tinker with such matters.
                              • #30
                                I'll have to take a closer look at Joe's. I have plenty to keep me busy for a long time.
