Need Starter Autolite 12V for 185ci engine in 1950 Champion
  • Need Starter Autolite 12V for 185ci engine in 1950 Champion
    1) Finishing a restoration of Champion '50 9G-C5 w/ 185ci engine from 1956. Converting 6 to 12V. Starter I need is from Champion 1956-1959+
    AutoLite Model MBG-4103, 12Volts w/ 9 teeth pinion gear and 151 teeth ring gear for Standard Trani/OD
    I am looking for this 12V starter either rebuild or in good condition ready to use.
    2) I had my 6V starter just rebuild:
    used in Stude Champion 1950-1955 w/ 170 ci engine
    AutoLite Model MZ-4157, 6Volts, for 124 teeth ring rear and 9 teeth pinion gear.
    My starter does not work for 6 to 12V conversion due to 151 teeth ring gear
    Consider using my 6V starter to swap for a 12V starter or use if for discount on ust rebuild 12V starter.
    3) Also for sale just rebuild Generator AutoLite 6Volt Model GDZ6001A used in 1950-1955 Champions. $100 + shipping
    4) Final Question:
    Does the 12V Starter (from Champion 1956+) would fit and align in the bell housing of the 1950 Champion?
