early 1953 studebaker vin, (serial) numbers
  • early 1953 studebaker vin, (serial) numbers
    is there a number where studebaker stopped using the mercedes star logo after they were sued? i have an early starliner with the mercedes star identification; really curious as to where it fits into the picture. thank you.
    gfperry
    Yes, it's covered in the body parts book. US cars are listed by body numbers so you'll need the information on the firewall body tag.
    Canadian cars are listed by serial number.
    Another thing about wearing a mask......I don't have to shave before I leave the house!
Name:	53 and bells diner 045.jpg
ID:	1717470I think it was at least 3/4 of the production year. I have one of these, and curious myself. This one has the tri star wheel covers, radio delete, ash trays, horn button........ and may be for sale.
        On the C/K bodies, at least, I believe, the Vernon assembly plant in southern California, used them throughout the entire 1953 model year.
        Mark
        S2Deluxe = (5H - C3).
          Studebaker was NEVER sued by Mercedes Benz over the use of the Tri-Star. They were cordially asked to cease using it without even the threat of legal action. After all, four years later, Studebaker-Packard took over the distribution of Mercedes Benz products in USA and Canada.
            They continued to use the tristar as a raised section of the back-up light lenses on C/K cars until 55. That was aldo the last time they used glass for major lenses (except for license lights.
            Bez Auto Alchemy
              Your forgetting the Avanti headlamp lenses those were glass in fact Avanti Motors had to do a recall because of the glass headlamp lenses in the late 60s or early 70s as glass lenses were deemed to be unsafe.
                Mark
                The hood and trunk tristars were used throughout the model year on 1953s assembled in Vernon (LA).
                  i haven't purchased a body parts manual as yet. the vin.# is 8323568, the body# is 4H-K5,8802.the body plate is attached by two phillips head screws. is that correct? the car was repainted with a color change 28 years ago; the plate and screws are the new color. i acquired the car from an 84 year old gent who bought it 50 years ago from the original owner; it has 29k original miles on her, with only 9k added in the last 50 years, so i have no reason to question anything, just curious. thanks for any help!
                  gfperry
                    ...the body plate is attached by two phillips head screws. is that correct? the car was repainted with a color change 28 years ago; the plate and screws are the new color.
                    That IS correct; and the body tag was screwed in place before final painting, so under it should be only primer. Not that anyone will ever care to look.
                    '33 Rockne 10,
                    '51 Commander Starlight,
                    '56 Sky Hawk
                      Per the 53-58 Body Parts Catalog, Pg 30 [Closed Bodies, U S A]
                      Note #24
                      Type "A" emblem [tristar] used on models before body numbers
                      14G
                      W1-2887
                      W3-9792
                      W5-12604
                      F1-1771
                      F3-4685
                      F5-2061
                      C3-3258
                      C5-10335
                      4H
                      W3-7729
                      W5-6014
                      Y5-13014
                      F3-1617
                      C3-3751
                      C5-11445
                      This would refer to the trunk emblem since the hood and front emblem is covered in the chassis parts catalog.
                      But I suppose the hood emblem would have changed at the same body number.
                      Note #25
                      Type "B" emblem [V] used on and after body numbers and car serials in Note 24.
                      Per Pg #257, [Open Bodies, U S A]
                      Note #21
                      Type "A" ornament used on models before body numbers
                      14G
                      K5-7547
                      4H
                      K5-15058
                      Note #22
                      Type "B" ornament used on and after body numbers and serials in Note #21
                      South Lompoc Studebaker
                        One of the South Bend built Commander Starliners that I owned had a S/N starting in 833XXXX (higher than yours). I knew that car since it was new and it had the Tri-Star hood and trunk emblems.
                        The Serial Number plate should be spot welded on and not painted. The body plate should be held on with Phillips head screws and be painted with the body.
                          55 56 PREZ 4D - (I didn't want to repeat your chart.) Your chart does not include the K body Starliners.
                            Per the '51-'54 chassis manual:
                            Type "A" aka tri-star hood emblems used on:
                            14G W & F body S/N G1245498 and earlier
                            14G C & K body S/N G1246604 and earlier
                            4H W, F & Y body S/N 8340196 and earlier
                            4H C & K body S/N 8339269 and earlier
                            Type "B" aka the V/S emblems start with the next S/Ns from those.
                            My own '53 K body is a 14G-K5 and S/N G1228619 and has the tri-stars. It was built in May of '53.
                            Jeff in ND
                              Your serial number indicates the car was built in May of 1953. That was the same month it was decided to quit putting the three pointed star on new production, but they kept them in parts stock for replacement purposes.
