60 lark dual exhaust frame bracket.
  • 60 lark dual exhaust frame bracket.
    I am putting an Avanti engine in a 60 Lark 2 door wagon. I have two other 60 wagons for parts,etc. All 3 have a frame bracket bolted to the right side frame rail for the exhaust hanger. This bracket isn't on the left side to accommodate a dual exhaust. Was such a part made and is it available?
    I looked in the chassis catalog and it doesn't shown the bracket on either side.
    I re-bent a right side one when I put duals on my 64 Daytona. Welded the edge were I thought it was weak from bending.
    I tried running the 65 part numbers on S.I's sight but they weren't showing up.
    Here's a link to an auction that had reproductions, might be Fairborn Stude.
    1539857 if I understand the parts system is left?
    http://www.ebay.com/itm/STUDEBAKER-D...p2047675.l2557
      Another post were they did the same thing and bent the bracket.
      http://forum.studebakerdriversclub.c...xhaust+bracket
        I'm sure someone nearby has an extra bracket from a parted GT
        Rob in PA
          When I put dual exhaust on my 60 Lark convert, I bought the bracket you are talking about from Don Simmons of Silvertone exhaust. He is a regular advertiser in Turning Wheels and attends most swap meets.
          Bob
          Bob
          Welland Ontario
          60 Lark Convertible
          64 Daytona
            Classic Enterprises sells the bracket too.
            Paul
            Winston-Salem, NC
              thanks everyone, I will try buying one before I start bending
                These are cheaper and painted..
                http://www.ebay.com/itm/292248872536
                In looking at the purchase history, the first one is minutes after your last post. I'll assume you already fond these.
                  Fairborn Studebaker has these in stainless steel at a reasonable cost. The originals rust out. Recently installed a set on a 1953 coupe.
                  sigpic 1963 Studebaker Avanti: LS1 motor and T-56 transmission have been moved rearward, set up as a two seat coupe with independent rear suspension. Complex solutions for nonexistant problems.
                    yes,ordered as soon as I found them. Now they are everywhere.
                      Would these work on a Champ pickup?
                        The truck frame is completely different from the cars. In addition, because of the gas tank placement, the duals on a truck need to both run down the right side of the driveshaft.
