R1 water pump pulley
  • R1 water pump pulley
    someone (champstude64@aol.com) (?Ken Fedor) had a water pump pulley for R1 on the swap page. Can't reach himso if you see this and it is still available, I am interested. Jeff Cassel (jccatwb@gmail.com)
    It's Sold, I already asked and we are weeks TOO late, for most all of it.
      Jeff, Rich,
      If you need Avanti water pump pulley, I have a couple of spares.
      78 Avanti RQB 2792
      64 Avanti R1 R5408
      63 Avanti R1 R4551
      63 Avanti R1 R2281
      62 GT Hawk V15949
      56 GH 6032504
      56 GH 6032588
      55 Speedster 7160047
      55 Speedster 7165279
        Water pump pulley
        Originally posted by 64studeavanti View Post
        Jeff, Rich,If you need Avanti water pump pulley, I have a couple of spares.
        Rich ; Just now saw your message. I would be interested in the pulley to try on my 64 Hawk with AC. You can send me a pm or my email is jccatwb@gmail.com Jeff
          Here's one on Sacramento Craigslist for $50
          https://sacramento.craigslist.org/pt...400040688.html
          sals54
            Jeff,
            I have a couple for Avanti. But I don't believe they will work on a stock JT/JTS.
            78 Avanti RQB 2792
            64 Avanti R1 R5408
            63 Avanti R1 R4551
            63 Avanti R1 R2281
            62 GT Hawk V15949
            56 GH 6032504
            56 GH 6032588
              Are they not the same??
              sals54
                I believe JT/JTS used "regular" water pump pulleys. I can find no different part numbers in the JT section of the chassis manual. The Avanti pulley is a heavy cast iron affair with 3 grooves. One is for the alternator. The other 2 are for S/C if so equipped. If A/C car, one is unused. The JT/JTS crank damper has a groove on it so the stock water pump pulley and altenator can be used.
                78 Avanti RQB 2792
                64 Avanti R1 R5408
                63 Avanti R1 R4551
                63 Avanti R1 R2281
                62 GT Hawk V15949
                56 GH 6032504
                56 GH 6032588
                  Henry, you can run a regular pulley but a JT/JTS factory pulley is 6 5/8 dia so it will spin the pump quicker compared to a 7" regular.
                  I have one if you want an original.
                  Brian Greenall
                  Melbourne, OZ
                    Be careful in changing out your water pump pulley to the R, smaller diameter, if you have AC. If the AC belt rides on accessory pulley on the water pump you will need to change it too.
                    Its all about ratios.
                    If your Crank pulley has various diameter grooves for each of the drive accessories, you need to keep the ratios. You can not spin the water pump faster while keeping the AC the same ratio. It makes a horrible sound.
                      never seen a cast iron water pump pulley; pump wouldn't last 100 miles with all that weight on it. I want to spin the pump just a bit faster to see it it will run a little cooler on a warm summer day. Not talkin bout the crank pulley. Packard Hawk: if you have one how much do you want for it.?
                        Jeff,
                        You could also try the heavy duty 6 blade fan with or without viscous drive. I also have the smaller pulley (non-Avanti) as well as 5, 6 and 7 blade fans. I have 6 blade with or without viscous drive. The 5 and 7 are with viscous drive.
                        78 Avanti RQB 2792
                        64 Avanti R1 R5408
                        63 Avanti R1 R4551
                        63 Avanti R1 R2281
                        62 GT Hawk V15949
                        56 GH 6032504
                        56 GH 6032588
                          Jeff, I would want 50.00 bucks for it but it might be another 25 bucks shipping from OZ.
                          You might be able to obtain one from Dave Thibeault.
                          If you get stuck Pm me and we can work it out.
                          Brian
                          Brian Greenall
                          Melbourne, OZ
                            Is this an Avanti water pump pulley?
                            We've got a couple of them but I wasn't confident enough to put a part number on them.
                              Matt, sure looks like it. BTW, SI and your site have an incorrect description for 1563110. This is an aluminun pulley with 2 grooves for A/C cars that came as part of an idle cooling improvement kit referenced in service letter R-1964-4 dated Apr 24, 1964.
                              Both sites say this is a 3 groove pulley.
                              This service letter is dated 4 months after the line shut down. I think it is highly unlikely that any Avanti came from the factory with this kit installed.
                              78 Avanti RQB 2792
                              64 Avanti R1 R5408
                              63 Avanti R1 R4551
                              63 Avanti R1 R2281
                              62 GT Hawk V15949
                              56 GH 6032504
                              56 GH 6032588
