I am in the process of replacing the engine in my 1962 Lark with a Chevrolet 283. Someone who has done this please let me know what to expect.
Engine swap
I will ask why? You can bolt in a Studebaker 259 or 289. If you are h--- bent on doing this swap, look at a 1965-1966 Studebaker Lark-type. They used the 283 GM engine (in the V8 models).Gary L.
Lark and Avanti share the same frame and Avanti's after 66 came with SBC's. The front mounts are available from our vendors. Best bet is to use the chevy based transmission of your choice and build the rear mount as needed. Pretty straight forward from there if you've done a swap previously. There's a lot of detail involved but there's probably not an easier swap around. As you go, if you need help just post questions or PM me. Bob
Mike is spot on. Even though you can use a lot of the parts from a 65-66 Stude, there is still plenty to engineer and fabricate.
Here's an old thread when I put a 305 and TH350 in a 63.
http://forum.studebakerdriversclub.c...steinkamp+lark
Sorry about the pics. I was using PhotoBucket then and they no longer support their inclusion in forums unless you pay their ransom.
If you right click on one of the photobucket pictures then click on "copy image address", then open another window and paste the image address in the address bar, you can view the image.Last edited by Dick Steinkamp; 09-05-2017, 08:20 PM.Dick Steinkamp
Bellingham, WA
I have done this swap three times already with the aluminum motor mounts that our vendors carry and it is no big deal. The only part I had to fabricate is the transmission mount and that was not hard at all! I have put a SBC in a 59 wagon, a 60 Lark, and a 63 Daytona. I did use the Jeep aluminum conversion radiator to aid in cooling and that was a simple bolt in as it fits perfectly with just to bolt holes to drill. The rams horn exhaust manifolds work really well with this conversion.1958 Transtar 3E6-122
1958 Transtar 3E13-31
1959 Transtar 4E7-122
1959 Lark 2 door Wagon
1960 Transtar 5E28-171
1960 Lark Gasser
1963 Daytona
I have a 350/700R4 in a '64 Daytona (4 Dr.). With the proper mounts (factory in image 1) the engine bolts right in. Since I already had a 65-66 McKinnon transplant I couldn't tell what carb linkage changes are needed but I'd assume they are few. Exhaust were center dump Ramhorns (clearance can be an issue to watch for).
With the 700R4 all I needed to do was elongate the crossmember bolt holes and for my own piece of mind over indented it. Not sure I even had to do that. The Batwing (image 2,3), that is what took a far degree of fabrication. I had to cut a lot of it away and then reinforced it with square tubing. Otherwise I used a stock Chevrolet trans mount. Even the drive shaft was a "bolt in" from a '78 Buick Skylark (4 Dr.). A plate type trans cooler (F-150 sourced) was added. I went from the linkage actuated column shift to a cable floor mount shifter from a 95 Camaro. I did have to fashion my trans dipstick tube as the sourced car (92 Buick Roadmaster) tube hit the firewall. That was done with 1/2" conduit and the original ends connected once the needed shape was achieved.
On a scale of 1-10 I'd call it a 3+ in difficulty and relatively straight forward.Last edited by wittsend; 09-06-2017, 01:14 PM.'64 Lark Type, powered by '85 Corvette L-98 (carburetor), 700R4, - CASO to the Max.
1963 Larks did not have 283 GM engines, only 65 and 66s did. If you got a V8 from a '63 it is most likely either a 259 or 289 Studebaker, unless of course someone else installed a 283 GM in the '63 at some time in the past.Dan White
64 R1 GT
64 R2 GT
58 C Cab
57 Broadmoor (Marvin)
Easiest way is to Google "SBC wiring diagram". Everything revolves around the starter solenoid so be sure your diagram reflects that area well. Be sure the battery + goes directly to the solenoid and the ground to a bolt on the engine block and on to the frame. Add a year like 1963 to the search until you find one you like.
I always rewire the whole car with one of these. http://www.speedwaymotors.com/Speedw...ss,229874.html as I don't trust any wiring that age. This kit is cheap, has great directions and all the wires are labeled every 6 inches. Can't go wrong!! Bob
Originally posted by preacher View PostThanks for the info. Explain how to wire the engine. I am installing a 283 from a 1963.Gary L.
