trans-missions
  • trans-missions
    I have a 64 G/T with and auto-trans shift bis on the steering columm trying to change it to a auto floor shift. I need the two levers that mount on the side of the trans--believe their called a kick down and a selector I cant find the part #'s in the parts book.can anyone come up with the #'s and better yet were I might gets my hands on them'''
    thanks for any help you all can give me.
    jmd33
    The gear selector lever for a floor-shift Flight-o-matic is 1543775 The "kick-down" as you call it, is 1541015 but it's no different than the one for the column shift arrangment.
    Miscreant adrift in
    the BerStuda Triangle
      Miscreant adrift in
        I don't think that I have ever seen a FOM with a floor shift. The 1543775 would be the selector arm for use with the Powershift transmission. I suppose that it could be used with the FOM, though. But, if the Powershift linkage and shifter are used, they would be the wrong pattern (PRND21 vs PNDLR), and the button-operated lockout for reverse would be in the wrong place. The neutral safety switch wouldn't work properly, nor would the back-up light switch.
        Has anyone successfully adapted a FOM to floor shift? How was the shifter adapted?
        Jim Bradley
        Lewistown PA
        '64 Daytona HT "Rerun"
        Jim Bradley
        Lake Monticello, VA
        '78 Avanti II
          Jim Bradley
          Lewistown PA
          Jim Bradley
          Lake Monticello, VA
          '78 Avanti II
