I have a 61 Hawk. I know the 62 fender is listed as non-interchangeable, but I was wondering the the differences are minor enough that it could be altered to fit. Thanks in advance.
Can a 62 Hawk fender be altered to fit a 61?
As far as I know the '62 Hawk fenders (front) will fit earlier C&K models. Holes for trim will be different. Remember that the side grilles on the '62 are the same as '56-61, except not chromed. The quarter panels (often called rear fenders) should interchange except that the top rear portion is different on '62-64 than earlier due to the stainless steel trim extending all the way back to the taillamp on the G.T. Hawks. The '63-64 Hawks have completely different side grilles than earlier cars, necessitating an indentation in the fender for the side grille to fit. Even this could probably be worked out to fit an earlier Hawk with hammer and dolly and filler.
-Dwight
If it were mine I would not hack it all up to fit, I would just have a qualified Body Man cut the front end off of the '61 Fender and weld it to the '62 and slap it on.
You would also need to check the compatibility of the Inner Fenders as well, you may have to save the '61 Inner.StudeRich
A very easy swap, since apron and nostril mounts are identical. Only thing needed is to fill in the GT stainless holes and spear slit holes, then drill new holes for the 61 stainless. No need for grafting of anything. Hopefully, the owner has the chrome 61 nostrils, with 61 parking lights. Could easily use the painted ones from 62, as they'd be a bolt in, but would be, "incorrect".
Originally posted by JoeHall View PostA very easy swap, since apron and nostril mounts are identical. Only thing needed is to fill in the GT stainless holes and spear slit holes, then drill new holes for the 61 stainless. No need for grafting of anything. Hopefully, the owner has the chrome 61 nostrils, with 61 parking lights. Could easily use the painted ones from 62, as they'd be a bolt in, but would be, "incorrect".
Originally posted by WayneXG95 View PostI've often wondered why that happened Quentin - And they used Split bench seats instead of buckets?
My avatar shows our 63 GT which has a 54 right rear fender. My signature shows my 57 Silverhawk which has a 62 GT right front fender. I simply placed a small piece of metal under the holes on top of the fender and welded up the hole with a Mig Welder, ground it down, and bolted it on.Neil Thornton
