Identifying V8 Engine
  • Identifying V8 Engine
    I'm considering the purchase of a Studebaker V8 listed on craigslist. Unfortunately, it's too far for away for me to inspect it.
    Based on the location of the oil filter, it looks to be a full-flow block.
    The seller tells me the casting # is 1554641 and the engine number is V581072.
    I checked http://www.studebakerdriversclub.com/V8EngineID.asp and didn't find a match for this engine number.
    Am I reading the web page incorrectly or possibly seller mis-reported the engine number?
    -- Scott
    64 Avanti R1 R5529
    The "V" would be a 259" motor. "P" is 289"
    It is an addiction!
      The engine serial number should make it a 1963, 259cu" Lark engine, which would have a full flow block. Unless the seller is declaring it to be something other then that, I don't know why you doubt what it is. Remember, the number shown on the published, engine sequence chart is the starting number for that year, and no ending number shown for 1963.
        Thanks Hallabutt, for clarifying "the number shown on the published, engine sequence chart is the starting number for that year".
        -- Scott
        Today, 12:57 PM
        Hallabutt
        Today, 12:57 PM
        Hallabutt
        64 Avanti R1 R5529
          PCV set up suggests 61+ V8
            Looks to be very clean compared to many I've seen over the years. Only thing I can see missing is alternator tension arm. Isn't caked with grease and grime from years of having had oil leaks and from pictured angle looks like driver's side valve has factory black over spray. I'd swing it in as is and take a chance. That is if it isn't over priced.
            Just my humble input,
            Kim
              Could be a "Junkyard" Engine, since all the hoses are Cut, or NOT.
              But it is very complete right down to the Converter Housing, (probably Torque Converter) and
              Borg Warner Flight-O-Matic Trans.
