Would someone please post a photo of how the jack is stored in a 57 Commander 4dr , where the spring attaches?
57 Commander Jack storage
There should be a small metal Loop/Hook at the outboard, Right rear corner of the floor, it goes from there to a hole in the movable part of the Bumper Jack.
Always carry a Hydraulic Bottle Jack or Scissor Jack to lift the Car, the bumper Jacks are a joke because they are dangerous and damage the Bumper.Last edited by StudeRich; 07-16-2017, 12:45 PM.StudeRich
I'm at the stage of remounting my original spare and jack assembly as well for my '59 Lark 2dr ht. I don't have a spring and can't seem to find any method of securing the jack itself on the right side. No studs or bolt holes are evident. Any help or suggestions?
Thanks, Bill
The '57 Sedan jack secures to the Right Inner Fender through the square hole in a Bracket under the front Lid opening.
The Larks just lay under the tire, clamped by the tire with the Large Washer and center bolt holding it down.StudeRich
Originally posted by tim333 View PostWould someone please post a photo of how the jack is stored in a 57 Commander 4dr , where the spring attaches?
Nick
Rich,
In my unmolested '59 Lark, I can see the spare and jack base retains the wheel assembly with a center bolt. I even have the cardboard cover which states "slide" left & right on the jack base. On the right side up high there is a rubberized pad for the jack to sit on but once the spring is attached there doesn't seem to be enough pressure to hold the jack down securely. There is a raised relief on the floor for the jack to rest (lock) against and it has a small hole for the spring to hook into and then reattach up to the sliding mechanism on the jack itself. I understand you are then supposed to tension the spring and jack by activating the sliding mechanism until pressure is noted(this is what appears in the owner's manual). But as I stated it doesn't seem to be substantial enough to secure properly at that top tab. The jack itself will probably never be used again but I would like it to appear as original as possible and not flop around in driving conditions.
Thanks for your assistance.
Cheers, Bill
