Or more accurately: How are the studs poking through the underside of the hood attached to the stainless strip. I found a rusty M-series hood with good stainless. The nuts are really rusty, as is everything else. Are the studs spot-welded to the stainless, or is there some kind of fastener/clip that the studs screw into? I used a Dremel tool to partially grind through the nuts on two sides. I didn't want to cut into the studs if that's all there will be attached to the stainless strip. Thought the nuts would then break off of their studs. I tried two and both studs ended up turning.
