1977 Avanti II Cruise Control Transducer
  • candbstudebakers
    I removed one from the 76 damaged car but not sure if saved or not but if I did I will bring to S/B along with some other parts from that car.
  • WinM1895
    Originally posted by Tom Clarke View Post
    My Avanti II is a 1979, and the Cruise Control suddenly quit working. I have power to the transducer box so I removed it and found that it is stamped "Dana Corporation - Perfect Circle - Controls Division". I the cover (6 screws) and noted there were points inside. Thinking they may have lost contact, I used a points file on them, put things back together and it still does not work.
    I have searched the web, without success, trying to find a replacement transducer, or a repair facility. Can anyone help?
    Where is the Cruise Control switch, clipped onto the T/S handle?
  • sweetolbob
    Rostra took over from Dana. You might try to contact them but I'll bet chances are slim they have parts that old. You could also search Ebay for a Dana universal unit. Might be the same controller.
  • Tom Clarke
  • studebu
    I could not find any numbers on the Transducer other than Delco stamped in housing.
    I checked on Ebay and found a listing for two different Transducers for a 1976 Chevy. One had a two wire plug and one had a 3 wire plug.
    I ordered a Cardone 36-101 Remanufactured Transducer with a 2 wire plug from Big Red Auto Parts, Fontana, Ca for $81.00 plus shipping. Cruise control works good now.
  • Skip Lackie
    It is almost certainly the same one that was used on 76-77 Chevy small block engines. If the old one is still there, it should have a Delco or aftermarket number.
  • studebu
    started a topic 1977 Avanti II Cruise Control Transducer
    Does anyone know what number Cruise Control Transducer is correct for a 1977 Avanti II?
