I have a 54 champion coupe. Their a pump on the floor. How does the pump work getting water to the windshield? I have no connection on the pump or water resevior to see how it works.
54 champion coupe windshield pump
There will be a connection on the bottom of the pump. Some pumps had 2 connections so you will have to check which style you have. If you have one connection (most likely on 54) it will have a hose which will run to the larger fitting on top of the bag or jar. The smaller hose will then run to the sparayer(s) When you pump then it creates pressure to force the fluid out of the bag or jar.
If you have a non-studebaker version then it probably works similar.
You will need to check the pump to make sure it is still putting out pressure.
The pumps with two hoses ran the fluid through the pump which meant they tended to fail
Good luckMilt
1961 Hawk 4-speed
1967 Avanti
1961 Lark 2 door
1988 Avanti Convertible
Member of SDC since 1973
The single hose pump will have a valve that prevents backflow attached to the top of the washer bag. The double hose pump has the valve inside the pump."All attempts to 'rise above the issue' are simply an excuse to avoid it profitably." --Dick Gregory
A small triangular Glass Bottle of Studebaker Concentrate to mix with water and add to the Reservoir was used mounted on an inner Fender on some models and years, but all of the Pump Reservoirs were Bags on earlier Cars and Plastic bottles on later ones.
If you have a Large round glass bottle, the system or parts of it is likely Aftermarket or GM.StudeRich
If you have a Large round glass bottle, the system or parts of it is likely Aftermarket or GM.And you can just barely see the check valve in the top of this reservoir. It is white nylon with three orifices and a tiny metal cap.
Originally posted by barry gibbons View PostThanks, now I need to look for a bag type water container."All attempts to 'rise above the issue' are simply an excuse to avoid it profitably." --Dick Gregory
