Mirrors, Mirrors, Mirrors... Mid 1950's
  • Mirrors, Mirrors, Mirrors... Mid 1950's
    What are the best options for a '56 Hawk? I've read that the SI reproductions are so-so and that some of the eBay options may be as good or ever better.
    So what say you???
    Not being as interested in authenticity as functionality, I got a set of these...I prefer them over plastic and/or round mirrors.
    http://www.ebay.com/itm/Chevy-Car-Ou...hWYeX8&vxp=mtr
      Lot of choices in 55 57 Chevy type from $20 and up. Most cars back in the day did not have factory mirrors. Western Auto Sears Wards and local parts stores sold mirrors. Guys back then did not worry about OEM parts. Better to have helper when installing Passenger side to get correct location to be able to see from drivers seat. Check Summit Racing they sell them
        I am OK with other than, "correct" Stude mirrors, but at least go with era correct mirrors, i.e. round lenses for 50s-60s Studes. Actually, the re-pop mirrors for 1956 Studes hold up very well. However, I cannot say the same for the re-pops for GT Hawk. The cast metal is not as strong as was the original, so the ball-pivot tightening screw will break the cast metal quite easily.
          I'm thinking that once I get the mirrors adjusted just right...add a drop of Super Glue to the pivot?...
            For sheer functionality, the mirrors that clamp on to the front edge of the door are the best, and would also be period correct.
              These '55 to '57 GM Repro Mirrors are the best Quality out there.
              Tinted Glass, Right Hand "Objects are closer than they appear" Wide Angle glass available on request, Stainless Steel front of mirror Head, molded Rubber gasket with a bead, only one visible screw mounting, Quality Chrome finish on Base.
Name:	55_57 Chev Mirrors.jpg
ID:	1712627 Sold by: mr.fifty on eBay
                50's area mirrors
                Summit racing has them for $22. Also the convex for the passenger side. They are nice. Easy to mount also.
                https://www.summitracing.com/parts/u...5728/overview/
                  I used the ones StudeRich posted, they look and work good.
                  Dwight 54 Commander hardtop
                    I avoid the HUGE Co.'s and buy them from the "Little Guy" 6 bucks a Pair more doesn't bother me.
                      I can't speak for the 56 mirrors but I paid a large sum of money for "regal mirrors" ....they are re-pops and I knew this when I bought them but were touted as being of the finest quality. One is a different color of chrome than the other and both of the screws that mount the mirror to the base will not stay tight. It is a #3 phillips oval head screw and if you try to tighten them up too much the countersunk hole in the casting splits. This I know first hand. they are purely for decoration anyway cause you don't see well behind the car with them. After paying all the money for them I cuss these mirrors every time I have to re-tighten them up. And you have to keep them tight or they will flop over and dent your door... I also found this out first hand. The countersunk hole for this screw is slowly spreading out and allowing the mirror to come loose. These mirrors soured my taste for anything and all re-pop. I wanted to return these as soon as I realized they were substandard quality but by then the mounting holes were drilled into my sheet metal. As soon as I come across a NOS pair of these I will be comparing them to mine and if they will stay tight I will buy them and replace mine and chalk this up to experience. So my take on the re-pop mirrors is buyer beware!
                        [ATTACH=CONFIG]62357[/ATTACH] Sold by: mr.fifty on eBay
                        I think that these will be the choice. A little more $$$ but then again, you get what you pay for.
                        I'll be ordering a set shortly… Thanks!!!
                        And I thank all who responded and aided in this decision...
                          So what say you???
                          Don't put mirrors on the outside of your car! They will only slow you down and make you burn more fuel.<G>
                          Besides, turning your head to see what's beside you is good exercise.<GG>
                          Jerry Forrester
                          Forrester's Chrome
                          Douglasville, Georgia
