This channel is for questions about how to use the Forum.
Please do not post automotive questions here.
PM still doesn't work
  • PM still doesn't work
    Just tried again to send a PM. Still says I have "exceeded the limit of 100 saved messages", but I only show 5. If Clark could fix this it would be great.
    Proud NON-CASO
    Romans 15:13
    Deuteronomy 31:6
    Proverbs 28:1
    Illegitimi non carborundum
    Bob, the items in your "Sent" folder count towards the 100, and the items in the "Trash" folder count towards the 100. Yes, it's a klunky not-very-user-friendly system, but you have to go to the Sent folder and delete them, then go to the Trash folder and delete them.
    You probably already know this, but thought I'd mention it.
    By the way, that's a nice '62 hardtop you got!
    Paul
    Winston-Salem, NC
      Thanks, Paul, it is a beauty. For the record, I cleared out everything as best as I could figure out, and still no luck. I tried to PM Clark and that wouldn't even go. All I have left is posting here and hopefully Clark will see it.
      Proud NON-CASO
      Romans 15:13
      Deuteronomy 31:6
      Proverbs 28:1
        showbizkid
        ​​​​​​​Bob, if you type an "at" symbol and then Clark's forum name (showbizkid) it will send him a notification to this thread. See just above.
        Paul
        Winston-Salem, NC
          showbizkid
          looks like you just did it for me!​​​​​​​
          Proud NON-CASO
          Romans 15:13
          Deuteronomy 31:6
          Proverbs 28:1
            It's also been noted in the past, any messages you have sent or received from others, that have not yet been totally removed from their cache, are still counted against your own totals.
            Yeah; that definitely makes no sense but, there it is.
            '33 Rockne 10,
            '51 Commander Starlight,
            '56 Sky Hawk
              Bob Andrews , I have manually deleted your old PMs. Remember, things in your trash must be emptied - they count against your total. Let me know if this does the trick.
                Also, here's the tutorial for doing this yourself in this sticky.
                  Thanks, Clark, as far as I could tell I had already deleted everything. We'll see if it works now.
                  Proud NON-CASO
                  Romans 15:13
                  Deuteronomy 31:6
                  Proverbs 28:1
                    Bob, if that fails, you could always go back to the old fashion way. Get the address, put a stamp on an envelope and mail it. Not only does that give a personal touch, but helps support our retirement from the USPS
                    Thank you to all the use the USPS to help Bob and Bob's and others that on the forum that have retired from the USPS.
                    Bob Miles
                      '33 Rockne 10,
                      '56 Sky Hawk
                        It’s working! Thank you
                        Proud NON-CASO
                        Romans 15:13
                        Deuteronomy 31:6
                        Proverbs 28:1
