I'm installing OEM manual window regulators in an Avanti fiberglass door and need help. Should the bolts (or machine screws?) have special heads to spread out the load? Do slotted holes need different bolt/washers? Are special lock washers needed? Should I use Locktite? On the back side of the reinforced, threaded plates, do I also need nuts? How should the window crank mounting plate be positioned in the (rear) slotted holes? How should the 2 guide track bolts be located in their slotted holes? And finally, how long are the bolts?
Note: Before installation, I will be re-aligning the vertical glass tracks (with their new felts) and the new (bottom) metal window support.
Thanks!
Thanks!
