I had my T-86 transmission rebuilt by a company in Tavares, FL. First and second gear work OK, but third gear will grind if you don't wait 5 or 6 seconds before shifting. I used 30 wt. non-detergent and I've tried several oils that were similar, but it still grinds. I pulled it and they took it apart and replaced a cage on sprag or something, not sure anymore, but it stills dose it. I noticed that the first mile or so it shifts OK, but it will grind if shifted to quick. I was wondering if it would hurt anything if I put 90 wt. gear oil in it as I think the oil is thinning enough to cause this?
Thanks, Gene
Thanks, Gene
